Zeke's Avatar
Plugged in another tach, no good
Here I am with an aching ass shoulder and I decide to change out my tach that I pressumably fried while welding on the muffler a while back.
The second tach doesn't work. Now, I'm not one to send it off to N. Hollywood speedo until I know that something else could not be causing this.
Ideas?
Oh, and if you don't answer me in 5 minutes, I'm gonna be "disappointed in the forum."
Old 06-17-2004, 02:47 PM
Early_S_Man's Avatar
Porsche Crest
Zeke,
Well, you could check for ground pulses at the tach input wire as you turn over the engine ... if they don't make it that far, there's the forward 14-pin connector and a couple of other stops meandering through the relay panel wiring to the CDI and Speed Switch. Those crimps are only 34-years old, you know!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-17-2004, 03:00 PM
Zeke's Avatar
Thank you sir. While you were answering, I was out in the car with the meter on the black/purple wire getting variable voltage with the rpm change. I guess both my tachs are dead. I've got one completely disassembled down to the electronic chassis and that's where my knowledge stops. No physical damage visable. All those diodes and whatnots keep their little secrets from guys like me.
What is the pisser about this is that I have the whole steering wheel, hub and covers off in order to get the tach out. I'm gonna have to do this twice!
Old 06-17-2004, 03:26 PM
Don't feel bad zeke, even EE like me needs a schematic to troubleshoot what the hell is wrong.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 06-17-2004, 03:28 PM
I woudl try to aligator clip a jumper directly from battery ground to tach ground. Same with the positive if it applies (dont have wiring diagram in front of me). Then try both the tachs. ps do they work in another car?
Thanks for the help in the past.
76/3.0 tarcabvertible
64 corvette conv.
72 Alfa GTV
79 Jeep Cherokee Chief
Old 06-17-2004, 08:06 PM
Zeke's Avatar
Good ideas there. I did all that. Don't have another 911 to swap instruments. Maybe that's what wrong.
I already put a dead tach back in and put the wheel back on resigning myself to a $125 charge to find a resistor or diode and solder it in. I need the turn signal lights and don't want to look at a hole. You know how us old guys like to drive down the freeway with the blinker going.
I'm just gonna wait for the first jerk that says, "That's not a real S, it doesn't have the 7300 rpm tachometer."
I know one thing, I have a lot more welding to do and the refurbished tach is not going back in the car until that's all done. So, I'm tachless. I guess that's better than being tacky.
Old 06-17-2004, 08:24 PM
