John Brandt's Avatar
what adhesive to use to hold power window in the channel?
I'm referring to the channell that grips the window and pulls it down with the power window mechanism.
mine came loose again. as it did about 5years ago. Last time I used some kind of clear silicone goop / caulk
it wasn't a pleasant job, and I'd prefer not to need to do this yet again in a few years. Got any thoughts on what would be a more permanent solution?
Old 06-16-2004, 08:16 AM
Registered abUser
TerryH's Avatar
Use quick set urethane after a thorough cleaning with degreaser. Make sure things aren't binding. The window should almost drop with gravity. You may want to lube the regulator and the glass run channel.
'81 911SC Coupe SOLD
Old 06-16-2004, 08:45 AM
thanks,
so perhaps silicone spray on the runners and lithium grease on the inside equipment?
Old 06-16-2004, 11:48 AM
TerryBPP's Avatar
Wayne told me to use 3M waterproof marine adhesive. It comes in a white/green tube. Worked great.
Old 06-16-2004, 11:51 AM
Registered abUser
TerryH's Avatar
Originally posted by John Brandt
thanks,
Those are the same lubricants I use. The quickset or fastset automotive glass urethane is very permanent. I would venture to say it's so permanent that something will break, ie; glass or metal regulator, before the bond lets go.
Like any repair of this sort, prep the area real well to get a good bond. I would use naptha or acetone to get good oil free surfaces.
Old 06-16-2004, 01:16 PM
I used the 3m marine adhesive, too. It may be worth replacing the channel inserts, too, in case thats causing the window to bind. They're not terribly expensive.
1968 911L
2004 Dodge Dakota SLT Plus
Old 06-16-2004, 01:19 PM
david914's Avatar
I went to a local glass shop. They gave me the remainder of a tube of urethane that is used to glue in windshields. Apparently, they frequently have partially used tubes of adhesive that just get thrown out since once opened, they don't have any shelf life. Worked great.
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 06-17-2004, 05:08 AM
