Noel's Avatar
Anyone use Ti Brake Shields to get more pad life at the track?
I am about to head up to Beaverun for a De event (Near Pittsburgh) and I just installed a set of Ti Shields from Seine Systems (I couldn't fit them in the calipers when the brake pads were new). I usually replace my pads at around 50% since I use them on the track. As such, I got to thinking about extending the life of track brake pads by building up layers of Ti Shields to compensate for pad wear. For example, use two sets of Ti shields when the pads wear enough to fit them in. This would help to prevent the issue of more heat transfering to the fluid as the pads wear. This could save some money buying Pagids or whatever your flavor is.
Any comments?
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 06-23-2004, 11:47 AM
beepbeep's Avatar
I don't get it? Shields just prevent some of heat going into calipers, pads themselves will still wear at same rate...
You don't need any shields to wear down the pads to the metal.
Thank you for your time,
Old 06-23-2004, 12:05 PM
Diss Member
Quicksilver's Avatar
Actually because a little more heat is held in the pad by the insulation of the shield, I would expect the pad wear to slightly increase.
The fact is that pads and rotors are expendable items. The only way to get better life is to re-engineer the system. Basically you need more heatsink mass (bigger rotor), better pads (better material, thicker, etc), or better cooling (this one isn't very effective).
Wayne
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-23-2004, 12:13 PM
KobaltBlau's Avatar
My thoughts _exactly_
Andy
Old 06-23-2004, 12:22 PM
"This would help to prevent the issue of more heat transfering to the fluid as the pads wear."
That's the sole purpose of the Ti Brake Shields, to reduce heat transfer to the fluid. If there are other issues with the brake system (pad fade, insufficient rotor cooling, etc.), look at improvements in those areas as well.
Sherwood
SeineSystems.com
Old 06-23-2004, 12:25 PM
Administrator
Jack Olsen's Avatar
I use them, and have never experienced brake fade. Why are you throwing away your pads halfway through their lifespan? Were you getting fluid boiling from less-than-50% pads?
My advice would be to diligently monitor your pad wear, and not add more than one Ti shield to a caliper.
Old 06-23-2004, 12:28 PM
Im thinking about those Ti plates but am wondering if its at all possible to split a pack between two cars/owners, as surely they are needed mostly upfront?
and am I right in thinking pad size is the same f/r on a 1983sc
Old 06-23-2004, 12:35 PM
To clarify, the Ti Brake Shield set includes 4 shields; enough for one axle pair.
MrKJBlue,
Yes, the front and rear pads are the same dimension on an '83 SC. BTW, I see no downside in inserting two shields in back of a single pad. The resultant air gap between the two sheets (slight as it may be), should help reduce the thermal conductivity path between the parts.
I briefly looked into sourcing Ti sheets with an embossed waffle pattern to create an air space boundary layer, but this would have tripled my cost for the already-expensive material.
Sherwood
seinesystems.com
Old 06-23-2004, 01:15 PM
304065's Avatar
Forget titanium.
Get yourself some Castrol SRF brake fluid and Pagid Orange front and rear, this will do it.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Noel's Avatar
I HAVE been getting rid of my pads when there is only 50% left due to fluid fade. I've since installed cooling. However, I was thinking that as the pads wear you are loosing thermal insulation to the caliper. As such, if one Ti shield is good, then two would be better? That was the whole frame of thought.
When do you guys toss your old track pads? What is the wear limit you use as a gauge for replacement?
Thanks again for the advice guys.
Old 06-23-2004, 01:16 PM
Bill Verburg's Avatar
Good idea!
Interesting idea, that would probably work ok, at least I don't see any major drawbacks.
The pads themselves are heat shilds, some better than others, the thinner they are the less R factor they provide.
Bill Verburg
Old 06-23-2004, 01:18 PM
bigrubberjeep's Avatar
Question = would there be any benefit to having a temperature meter on each brake caliper or at least the resevoir?
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 06-23-2004, 01:20 PM
Ho Hum 74's Avatar
John C,
I hear that Castrol is the stuff. Where is the most reasonable place to get it?
Tristan
Old 06-23-2004, 01:21 PM
Sorry my bad maths
4 parts=1 axle
I was thinking the pack was for front and rear.
Old 06-23-2004, 01:28 PM
PeteBrown's Avatar
Noel:
Quit using the brakes so much!! With your new suspension you should be cornering at increased speeds and not need the brakes -
All kidding aside, I replace my pads with about 25% or less left on the pad which usually happens on Saturday night during a DE week-end and when I don't trust that I have enough pad for Sunday.
I'm also switching to Motul 600 brake fluid as the ATE Super Blue/Gold creates a soft pad on initial braking thus I often resort to double braking.
Pete Brown
'87 911 Coupe
'20 718 GT4
'25 Aviator
'25 Mach E
Old 06-23-2004, 01:45 PM
A change in brake fluid may be all that's necessary. Here are some top overall performers from my fluid summary chart:
Brand, DOT spec, Dry spec, Wet spec
Castrol SRF DOT 4
590°F (310°C)/518°F (270°C)
GS610 Brake Fluid DOT 4
610°F (321°C)/421°F (216°C)
Brembo LCF 600+ DOT 4
601°F (316°C)/399°F (204°C)
Motul Racing Brake Fluid 600 DOT 4
594ºF (312ºC)/421°F (216°C)
Wilwood EXP600 Plus DOT 4
633°F (330°C)/417°F (213°C)
Sherwood
I'm not advocating, just reporting the published specs.
Old 06-23-2004, 02:04 PM
304065's Avatar
Wayne doesn't sell it: I bought mine from www.racerpartswholesale. Google "Castrol SRF," some guys may sell it a few bucks cheaper but you're looking at $70/liter probably.
Do a search here for "gravity bleed," you don't want to be pumping a couple liters of this stuff out using a power bleeder.
'81 R65
Old 06-23-2004, 02:17 PM
Me like track days
Craig 930 RS's Avatar
I have sold the Ti shields from Seine systems - they
do not do a thing for the pad life - but I have found they measurably improve the reduction in fluid boiling. I use them on the 930 brakes on my 79SC - no problems anymore (there were issues, believe it or not!)
Craig
@RS
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 06-23-2004, 02:39 PM
chrisp's Avatar
thin pads also have a tendency to crack rotors because the heat stays in the rotor..the pad can't dissipate enough.
Not sure how thick the plates you are talking are but is there a risk of the pad (should it be worn almost to the backing plate) falling out of the caliper?
'83 SC
Old 06-23-2004, 02:41 PM
}{arlequin's Avatar
I'm sure other places have it as well, but Truechoice sells stickers (similar in concept to the ones you put on an acquarium to monitor water temp) and they also have temp-reactive paint. Each pack of stickers, or paint, has enough different ranges for you to pick which one applies and "apply" it to the caliper. Paint changes color and tells you what temp range your caliper is operating at. (Stickers work the same.)https://secure.vbcomm.net/store/detail.asp?part=CLU5956K16
As far as using stacked Ti shields per caliper, I have one caveat. When you have too many (even two) per each side of the caliper, there is a chance they may end up getting wedged in a funny way. Depending how that happened, you may either not have enough braking force b/c you'll be hindered by the Ti shields, or, the shields will wedge themselves in such a way that when you get off the brake the pads will be prevented from retreating from the rotor surface, thus scoring and overcooking the rotor/pad/caliper anyway.
Search the web for thermal barrier paints and you'll come across applications for the backing plate of the pad. It's ceramic-type based paint that works wonders. I've even thought of using clean backing plates from used up pads for this purpose. I thought that coating them from both sides in such paint would be the solution, but a possibility of a locked up caliper keeps me from experimenting.
dave
1973,5
Old 06-23-2004, 02:46 PM
