adomakin's Avatar
930 turbo shell good for a 73 RSR project?
Ive got the chance to buy a 930 shell and was wondering if it will make a good base for a 73 RSR replica? I am building a 3.3 turbo engine for the replica so i realise that will work well with the loom but im thinking more of things like using 11x15 fuchs. do they fit ok with the small trailing arms? also, is the front nose convrsion a real $hit job or relatively straight forward? Also (and this IS the last 'also'!) whats the difference in weight between a 69 shell (what i already have) and a 79 turbo shell?
Andy, UK
Andy
1980 SC soon to be big hp 3.3t powered 73RSR Replica (well, I'm keeping the engine but everything else is going )
Old 06-27-2004, 12:42 AM
Administrator
Jack Olsen's Avatar
This is an early 77 tub with 9x11x15 wheels, I'm pretty sure. The owner's name is Barrett, and I believe he fit the wheels without any problem.
Old 06-27-2004, 12:51 AM
the front coversion is a lot of work i guess. You have to replace the front pan of the car. Or go with rsr latches offcourse then you only need the early fenders. Nick Moss has an article on backdating an SC on DDK somewhere it shows how the front is done with replacing the front pan. Ask Jack O or Tyson about the traling arms.
87 Carrera Backdate
Old 06-27-2004, 12:56 AM
http://www.early911.co.uk/backdate/html/body-mods.html there you go.
87 Carrera Backdate
Old 06-27-2004, 01:00 AM
adomakin's Avatar
cheers blokes
Andy
Old 06-27-2004, 02:21 AM
beepbeep's Avatar
11 x 15 wheels fit w/o problems. Been there done that. You should be aware that there is hardly any rubber left in that size. Yokohama 285/40-15 is not being made anymore and there are few pieces that can be bought from De Tomaso crowd.
Pirelli 315/35-15 (or something like that) are still being manufactured and are not so wide as you would believe.
Thank you for your time,
Old 06-27-2004, 04:44 AM
adomakin's Avatar
ive got the tyre prob sorted-check these puppies out.
michelin have just started re making them they are a classic tarmac rally intermediate tyre and they cost me far too much! (about 950 of your notes for a pair
thanks for the thoughts though beep. Andyone know the weight differences between the 69 shell and the 79 turbo shell?
Andy
Andy
Old 06-27-2004, 04:57 AM
unimog's Avatar
Re: 930 turbo shell good for a 73 RSR project?
Originally posted by adomakin
... is the front nose convrsion a real $hit job or relatively straight forward? Thanks Andy, UK
There is a good article in Dec. 2003 '911 & Porsche World' (#117) on this. The guy modified the fenders instead of changing them. If you use RS style rubber bungs for the hood hold-down, you can avoid the whole long hood latching piece issue.
(I can scan the article for you, if you can't find the magazine)
'04 BMW R1100S BCR
'01 Audi TT RS
gone but not forgotten:
'87 911 Carrera '59 356 Coupe
'66 912 Speedster '99 996 Ducati
Old 06-27-2004, 08:44 AM
adomakin's Avatar
nice one unimog, ill dig around for the mag but if i can't find it ill pm you (if you don't mind!)
Andy
Old 06-27-2004, 01:27 PM
