It's a trap...
My '81 was running and starting fine last week, now it won't start on the first or second attempt and it runs rough cold and warm, and backfires slightly at idle. Can this be bad gas? It coincided with a fill up. No other work done besides the fill up. Can I put dry gas in this engine without hurting it? Many TIA. Cheers, Mike
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). Last edited by Speed Buggy; 06-28-2004 at 10:07 AM.. |
It's a trap...
self serving bump - please help
Run like the wind, straining the limits of machine and man.... 2006 Atlas Gray Carrera 4, '81 911SC Black on Tan (SOLD), 2006 Acura RSX Type S, '13 Dodge Durango (wifeys). |
JOT MON ABBR OTH
I'm wondering if you didn't spring an air leak in the CIS.
David '83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)'15 F250 Gas (Her Baby) '95 993 (sold )I don't take scalps. I'm civilized like white man now, I shoot man in back. |
I second the air leak. Check all your hoses and your intake boots/clamps etc. Also check your airbox. Do you have the airbox pop-valve. If so, make sure that it's not loose and it's closed tightly. If not, check your airbox for cracks.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
It's a trap...
Thanks. Mike
Hey Speed, let me know it you need some help, I have the whole holiday weekend free. I would check plugs, dist cap, rotor, coil, air filter, and air leaks. Have you ever replaced the fuel filter? I heard you start your car on the drive and something is not right.
87 Carerra Coupe 04 GMC Yukon 07 Mazda 3 00 GMC Sierra |
Sounds like a vacuum leak, but you should also check fuel pressure with a CIS gauge. If you're fuel pressure is too high, you can have similar problems. If your WUR stops regulating pressure the pressure will go up.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
It's a trap...
Toolman - thanks for the offer. It will have to be some other time, though. I am going to the U.P. for the holiday to see my grandfather. I will get in touch if I need a hand. Have a great fourth. Mike
