whats that noise !
After hard acceleration when i release the gas pedal to change up sometimes i hear a noise a bit like the dump valve on a turbo,a kinda pressure release noise the car runs fine otherwise any ideas what it might be?
88 targa gone but not forgotten. 91 c4 coupe |
Go Speedracer, go!
exhaust leak?
1981 SC ROW Coupe |
Cheers CDiercks the car "burbles" nicely at low revs but is pretty quiet at speed,ive had cars with worn baffles/blown exhaust and they are generally a lot louder all the time the noise im getting is just as i get to red line and release the gas to shift gear.
Go Speedracer, go!
The only reason I mentioned it is that I just replaced my cat with a premuffler and have the same sound. I forgot to get new gaskets, and installed it with the old worn out gaskets until my new one show up on my doorstep. When the engine is cold, every time I shift I get that exact same sound you describe. Best of luck as I don't know what else it could be.
1981 SC ROW Coupe |
Cheers will get the exhaust checked out
