Rouxzy's Avatar
cylinder not firing - how do I find it.
I have a cylinder that is not firing. I know this because the car is running rough and it seems as though fuel is running right to the exhaust because I leave a trail of white smoke behind. This originaly happened just now and then, now it is constant. The car is in the garage until I fix the problem. Any ideas on how to find out which one is not firing?
Tom
Ice Green '77 Targa 3.6 w/ Steve Wong chip
One Way To Get More Horsepower Is To Get A Bigger Horse!
"I couldn't find the sports car of my dreams, so I built it myself"
Ferdinand Porsche
Old 06-30-2004, 01:20 PM
David's Avatar
Spray some light oil on the headers pipes were they exit the heads. It should be obvious which one is cold.
Old 06-30-2004, 01:29 PM
A Quiet Boom's Avatar
Or, pull one plug wire at a time until you find one that makes no difference in the way the car runs. Use a heavy glove so you don't get a jolt!
EDIT: oops SoCal beat me to it.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 06-30-2004, 01:30 PM
Rouxzy's Avatar
Thanks guys I'll give that a try.
Tom
Ferdinand Porsche
Old 06-30-2004, 01:33 PM
If you prefer not getting zapped you could back off each banjo fitting leading to an injector at the fuel distributor with a 12mm box end wrench.
This will cause a slight fuel leak at the fuel distributor but not a significant problem.
Cheers,
Joe
Old 06-30-2004, 02:10 PM
vash's Avatar
no, once you start the car, spray regular water on the headers. the dead cylinder will not immediately steam the water. work sorta fast, because the heat will travel to the dead cyl from the good ones and mask everything. disconnecting plugs works but the water is do friggen easy, why bother.
poof! gone
Old 06-30-2004, 02:15 PM
Gary H 1978 911 SC
After a short run time ( one or two min ) rub the exhaust stack with a crayon or the edge of a credit card. Crayon melts around 140*F while the credit card melts around 350*F. All should melt at the same rate, if not that is the bad one.
Gary H 1978 911 SC
Old 06-30-2004, 02:23 PM
vash's Avatar
old time motorcycle guy showed me that trick. best mechanic in the world. he got shot in a drive by in oakland, while gassing up. i pass his tip on, in his honor.
cliff
poof! gone
Old 06-30-2004, 02:44 PM
Irrationally exuberant
ChrisBennet's Avatar
I had a bad injector once and I tried disabling one cylinder at a time to find the bad one. It was far from obvious. I was surprised how subtle the difference was.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 06-30-2004, 05:08 PM
Zeke's Avatar
-Chris
No doubt. Sometimes you have 1 1/2 cyinders out. That's real fun. I like the water idea. That would even show a weak one.
Old 06-30-2004, 06:52 PM
Time Bandit
Jens's Avatar
Cheers,
Joe
Yikes! Gasoline?!!
Jens
RatBasterd- '70ish Ltwt Coupe, Factory IMSA RSR Bilstein coilovers, 993TT Brembos (Singer brakes) slotted & drilled, tweaked 3.0Ltr, 911R/ST pipes, DAS roll bar
Old 06-30-2004, 07:26 PM
You could take the plugs out and look and see which one is wet, if it is an ign. problem. If it is a fuel problem then that won't work.
I also wouldn't crack the banjo bolts. That would disturbe the sealing rings possibly
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 07-01-2004, 04:01 AM
Cornpanzer's Avatar
similar thought, but just wet your finger and see which pipes dont sizzle when you quickly touch it with your finger. Always works for me.
Check out my blog for Parts & Cars For Sale - http://renn-spot.blogspot.com/
1970 911S,
10 sec 67 Beetle (300 rear wheel HP)
RGruppe#252
Old 07-01-2004, 04:49 AM
Rouxzy's Avatar
Well,
I went the route of taking out each plug. They were all grey in color except for #2, it was black as coal. I check the resistance of the plug wire and it measured the same as the rest. I put in a new plug and it runs much better but still rough. I feel I have a fuel delivery problem which caused the plug to foul.
Ferdinand Porsche
Old 07-03-2004, 09:59 AM
Injector leaking?
1981 911sc Targa Rosewood (sold to Rob)
1983 911sc sunroof coupe Guards red
1986 930 (Sold, but not forgotten)
Old 07-03-2004, 11:07 AM
Unregistered
sammyg2's Avatar
If it's ignition related you can simply snap an induction fired timing light on to each wire, one at a time.
If it isn't sparking you won't get s strobe flash. If it is firing cortrectly you will get the light to flash.
Onliest problem here is if the wire is grounding and arcing through something besides the spark plug you will still get a signal.
Old 07-03-2004, 01:11 PM
vash's Avatar
sam, i did that once, and i got flashing from the timing light. but the badness was the plug. water bottle, you dont even need to jack the car up. set the water bottle on "stream".
poof! gone
Old 07-03-2004, 04:59 PM
