External T-stat question
It is my understanding the external t-stat is used in conjuntion with an exteranl oil cooler. I do not have an external oil cooler, why do I have a t-stat?
1978 911 3.0 fully rebuilt and for sale
Old 07-07-2004, 12:49 PM
vash's Avatar
this is an external tstat
what does your's look like?
poof! gone
Old 07-07-2004, 12:53 PM
Exactly the same. My oil lines head up around the front wheel well turn a few (ctualy more of a rectangle) and come back.
Old 07-07-2004, 12:56 PM
vash's Avatar
i now understand!
you have a trombone cooler. it really just lets the oil bleed heat into the atmoshere. i have the same thing, that works decent. i want to upgrade to the radiator type, soon.
poof! gone
Old 07-07-2004, 01:00 PM
Gon fix it with me hammer
svandamme's Avatar
good stuff, easy upgrade to radiator with fan style cooler
my PO removed the oillines and trombone
now i have to hook up new lines and sjit
Stijn Vandamme
BIMDIESELBMW116D2019
Old 07-07-2004, 01:02 PM
Doug Steinel's Avatar
Sounds like you have the so-called trombone oil cooler where there is a a series of steel loops just in front of your front left wheel. I admit it is not much of an oil cooler, but it is an oil cooler.
77 911, 3.0L
Perhaps someone can help me with a question re. replacing the insides of the oil line thermostat on the trombone oil cooler. I'm having some difficulty removing the grooved thermostat valve caps. It was recommended that I use a pipe wrench, but it just chews-up the cap. I will be installing new caps and don't want to damage them. Any suggestions on how I can make this job easier?
1974 911 Carrera Targa
Old 07-07-2004, 11:21 PM
vash's Avatar
pdad, i bet money that putting new ones on will not be near as destructive. just remember antisieze. just keep in mind that i have seen new tstats on the web for $270ish.
poof! gone
Old 07-08-2004, 12:52 PM
external t-stat
vash,
Thanks for the pointer about the antisieze. Bob at Pelican suggested a tool that should work for this job. I'm finishing up a brake job and then hope to work on the t-stats when I replace the heat exchangers. Seems as if one thing leads to another on these old cars. Sure are fun to drive, though!
Old 07-12-2004, 10:44 PM
