LM-1 Sensor Position
Hi
I'm intending to install an LM-1 AFR in my MFI 911, Where is the best position for the sensor, Headers or muffler?
If you put it in the header you would only be getting left or right cylinders, muffler is mixed but further downstream
suggestions?
Neven
73 911E, 70 914/6
Old 07-09-2004, 11:01 AM
What is the english version of your post?
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 07-09-2004, 11:05 AM
Would it help if you looked at
http://www.pelicanparts.com/catalog/shopcart/MISC/POR_MISC_INNOVT-detail.htm
Were the TLA's (Three Letter Acronyms) to much?
Neven
Old 07-09-2004, 11:10 AM
Grady Clay's Avatar
Neven,
I would choose mounting two bosses on the two muffler inlets, just behind the muffler flange and inwards and angled slightly up. This allows the sensors reasonable protection, you can monitor each bank of cylinders independently, and average to get the overall mixture.
Another location is on the heat exchangers, just ahead of the muffler flange. This puts the sensors in the path of debris from the tires. OK, if you protect the sensors.
There is not an easy way to install a sensor that combines both sides of the engine. If you put it at the tail pipe, there is unreasonable delay in the measurements and accumulated contamination of the muffler will dramatically affect the readings.
A MFI 911 should always use an OEM muffler.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 07-09-2004, 11:49 AM
Thanks Grady
I've got a Danske SS OEM Style muffler and SSI Heat Ex, so I was thinking that the muffler inlet pipes would be good (They cast, not SS)
PS Ive got my megasquirt board and bought a spare MFI pump on Ebay so the next step will be my eMFI system
Neven
Old 07-09-2004, 12:06 PM
Neven,
You're right. You can only use one WB sensor with the LM-1. So it's either the left bank or the right bank, or one bank at a time. I suggest welding the bung(s) in the collector, right after the individual pipes (3) merge together.
Another company uses two WB sensors and a single controller which is more convenient for multi-bank engines.
Sherwood
Old 07-09-2004, 12:16 PM
Sherwood
The single bank thing is not so much an issue with MFI as I can't
adjust left to right anyway (assuming throttles are balanced). Maybe I'd be better off putting in dual MAP sensors :-)
I've always found it amusing that the vaccum advance is connected to both throttle bodies. Very german, zere is zee
slight chance zee left bank has a different manifold vacuum at
idle zan zee udder bank so we connected zee distrubutor to both!
Neven
Old 07-09-2004, 12:29 PM
304065's Avatar
Well, there's an idea. Weld the sensor bung in the muffler instead of in the heat exchanger. A lot easier to weld in that vs. stainless steel.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 11-05-2004, 06:45 AM
Neven wrote:
"The single bank thing is not so much an issue with MFI as I can't adjust left to right anyway (assuming throttles are balanced). Maybe I'd be better off putting in dual MAP sensors :-)
I've always found it amusing that the vaccum advance is connected to both throttle bodies. Very german, zere is zee slight chance zee left bank has a different manifold vacuum at idle zan zee udder bank so we connected zee distrubutor to both! "
With or without MFI, a vacuum leak in one bank of cylinders (or one cylinder) is not going to be read by a single sensor installed on the opposite bank. That's why Porsche uses the total vacuum signal from both banks (or at least from a few opposite cylinders).
John wrote:
"Weld the sensor bung in the muffler instead of in the heat exchanger. A lot easier to weld in that vs. stainless steel."
Not sure about the response time from a wide band sensor installed in the muffler as this is a distance from the cylinders. The reading would be an average of 6 cylinders. The best setup would be to monitor each cylinder. Next best is each bank of three. Assuming all cylinders have the same A/F, it may not matter for steady state throttle positions. But that's an assumption, and you know how that sometimes shakes out. Anybody tried this?
Sherwood
Old 11-05-2004, 01:03 PM
304065's Avatar
Sherwood,
I was considering having the bung welded in the muffler inlet, just aft of the SSI's output flange. That's only a couple inches downstream and before the body of the muffler begins. In fact, I could weld a second bung in the other side, to be able to switch the sensor back and forth to verify that the crossover was set correctly.
I once tried to drill through Stainless Steel and destroyed a couple bits. My thought is that the steel muffler is easier to breach and simpler for the average muffler shop employee to weld on.
Having said that I'm going to get in touch with James Achard, maybe he can help, being a certified welder and all . . .
'81 R65
Old 11-05-2004, 01:13 PM
Hi
I have danske polished SS muffler and ended up putting the bung in the muffler inlet (which is the only non SS bit!)
Neven
Old 11-05-2004, 01:28 PM
304065's Avatar
Neven,
Could I trouble you for a photo of the installation?
'81 R65
Old 11-05-2004, 01:33 PM
John
If you can wait, unfortunately the engine has been reunited with the car down country and I won't be seeing it again for 2 weeks
Actually its not unfortunate, this is close to the end of a 10 year project, I'm getting a great xmas present!
Neven
Old 11-05-2004, 01:56 PM
Jeff Alton's Avatar
John, a high quality Cobalt drill bit makes quick work of stainless steel. Not quite like a hot knife through butter, but still pretty easy.
Jeff
www.turn3autosport.com
Old 11-05-2004, 05:32 PM
Author of "101 Projects"
Wayne 962's Avatar
I disagree completely. I have used this tool on many cars (incl Ferrari 308, Nissan Pathfinder, BMW 3-Series, and 911s), and the muffler location gives instant readings that correspond with readings from O2 sensors located upstream. You can monitor this by comparing the output of the LM-1 to the output by the OBD-II computers on post-1995 cars (like my BMW 5-Series).
Bottomline, for measuring and tuning, tailpipe is fine. Since you have two separate banks on your 911 engine, installing the O2 sensor on one or the other will only monitor 1/2 of your MFI system. It won't detect throttle-body imbalances, or clogged injectors on the opposite side. The side-to-side measuring difficulties are more pronounced with carbs.
-Wayne
Old 11-05-2004, 06:01 PM
Grady Clay's Avatar
Wayne,
“I have used this tool on many cars .…”
By “this tool” do you mean the LM-1 reading a WB O2 sensor? These are usually best closer to the exhaust port. Yes, you can buy the LM-1 tail pipe clamp for non-cat cars. I will yield to your experience that it reads the same as an upstream O2 sensor. Have you tried this comparison with a muffler contaminated with unburned fuel, oil, and carbon?
If you mean an Exhaust Gas Analyzer (CO & HC), I agree.
Many portable Exhaust Gas Analyzers don’t like exceedingly high temperatures for extended periods, such as on a dyno or road testing up a long hill. I made an ice water-to-exhaust gas heat exchanger to keep the temperatures under control.
I would love to have an EGA and a pair of LM-1s on a MFI 911.
John, Neven, Remember, an O2 sensor must be hooked up and running or it will get damaged. If you use two sensors, one for each bank, you either need two LM-1s or some method of powering the unused sensor.
Another issue is the sensor must be mounted somewhere in the 10-2 o’clock position, best is 12 o’clock, never in the 9-3 position, worst is 6 o’clock position.
Here is the manual for the LM-1:
http://www.innovatemotorsports.com/support/manual/LM-1_Manual_3.0.pdf
Sherwood, who manufactures the dual WB O2 sensor unit? Perhaps that is something Wayne might consider selling.
There is always subtle differences left-to-right on a 911. The CR can be slightly different, the cams can have slightly different timing, the cooling (or accumulated dirt) can be different, and of course the carburetors or fuel injection. I suppose it would be best to monitor each cylinder but side-to-side will yield an immense amount of useful information.
Best,
Grady
Old 11-06-2004, 09:29 AM
304065's Avatar
Wayne, Grady, thanks for the additional info.
I think I'll put two bungs in, one for each bank, and keep one plugged when not in use. This way I can switch the sensor back and forth to monitor each bank.
Grady, you must be tuned into my wavelength, as I was just reading that very passage from the manual this morning, where it says, don't mount the sensor in the bottom of the pipe. Given my tendency toward off-track-excursions I'm going to mount the sensor bungs as close to 12 o'clock as possible. I can just imagine going off and tearing the sensor wire out. . .
'81 R65
Old 11-06-2004, 10:36 AM
Grady Clay's Avatar
John,
Let’s do a little simple engineering here and design a switch for left-right. The sensors are relatively inexpensive. How is an O2 sensor powered in Factory configuration? The only issue I see is the LM-1 calibration cycle.
The advantage is tuning at “just off idle” and “very light throttle” at 3500 RPM.
How is your exhaust configured? Is there room to put a 3rd bung on the top of the tail pipe, inside the valance? That might be the best of both worlds.
Best,
Grady
Old 11-06-2004, 11:08 AM
one thing to look at would be a dual channel wb meter and run 2 sensors one for each bank, as far as the tail pipe goes with the short distances of the 911 exhaust your lag time will be minamal the lag time also has to do with what sensor you are using , ntk,lsu,ect they all have different response times.
Excell Racing
Boca Raton fl
Old 11-07-2004, 06:31 AM
"...... who manufactures the dual WB O2 sensor unit?"
Grady,
I thought I had a dual WB sensor vendor archived. I saw such a system in a recent issue of Race Tech magazine (new products section). I'll try to locate.
The following vendor offers a "dual, WB sensor system", but I don't know if this is standalone or used in conjunction with their fuel/engine management system.
http://www.3sxperformance.com/electronics.asp
Innovate Motorsports (LM-1) recommends no switching between multiple WB sensors in their single sensor system. The unswitched (and thus unheated sensor) needs power to prevent combustion byproducts from rendering it inaccurate or ineffectual. Don't know if there's a workaround this (e.g. a constant source voltage applied to the unswitched sensor).
BTW, it appears the term, "dual-channel" shouldn't be confused with two sensors.
Here's a list of single WB sensor vendors I've archived:
http://home.earthlink.net/~jcgebhart/msindex.html
http://www.widebandcommander.com/
http://www.zeitronix.com/Products/Products.htm
http://www.cyberauto.com/index.php/fjo_products.htm
http://www.techedge.com.au/vehicle/wbo2/default.htm
http://www.plxdevices.com/
http://www.innovatemotorsports.com/lm1.php
Sherwood
Old 11-07-2004, 02:12 PM
