How to do a search using 2 words?
I want to do a seach on "paint code" How can I make sure the search engine will only show posts where the 2 words are used?
Right now, I get all posts where paint is used and all those where code is used.
Old 07-15-2004, 02:13 PM
Bill Verburg's Avatar
use "and" in between them
i.e."paint and code"
Bill Verburg
Old 07-15-2004, 02:18 PM
steve911's Avatar
I tried that and it doesn't work. I also tried paint + code and "paint code" and got identical results.
My '85 911 Targa ** Hand painted center caps for sale here
RIP Warren
PCA & Rennlist member
Old 07-15-2004, 02:20 PM
It always works fine for me.
the search can be further narrowed if you know the name of the author.
Using and/or along w/ the author and even limiting search to only a single forum eliminates a lot of wasted time.
Bill Verburg
Old 07-15-2004, 02:44 PM
Az911's Avatar
Send a message via AIM to Az911
The search can also be narrowed by the sub forums. That way you are not searching the whole bbs
72T RS look
96 993
Old 07-15-2004, 02:46 PM
slater's Avatar
also i think the word "and" has to be in caps like "paint AND code"
What exaclty are you looking for?
1977 MGB (bright yellow)
1985 Honda Spree Moped (great for towing rollerbladers)
A flute without holes, is not a flute. A donut without a hole, is a Danish.
Old 07-15-2004, 05:58 PM
The paint code on my 79 SC is 708-9-3. I want to understand what it means.
I already know that 708 means Black metallic. I would like to know what the 9 and the 3 represent.
Old 07-15-2004, 06:08 PM
RallyJon's Avatar
To find posts with paint and code in the same post, select the "Show results as posts" radio button.
To find the phrase "paint code" Wayne would have to switch to other forum software.
993 · 911 · STI · S4 · rally car
Old 07-15-2004, 06:37 PM
"and" does not need to be capitalized,
you do nneed to think like a machine. The 2 words merely have 2 be in the same thread they do not have to be contiguous or even in the same post
Bill Verburg
Old 07-15-2004, 07:23 PM
banjomike's Avatar
look, you don't just want an article that has paint and code in it. You want an article that has the exact phrase "paint code". So use your quotation marks and search for "paint code". You ought to find what you need.
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 07-16-2004, 09:50 PM
708-9-3 :
708 = colour
9 = coachbuilder (9=Porsche)
3 = paint manufacturer (eg 2=Glasurit, I think 3=Lechler)
Andy
Andy
M&W 904 ... now gone
GT-style 356C ... also gone
Old 07-17-2004, 03:12 AM
Doug Steinel's Avatar
I have encountered the same problem and found it very annoying. Many search engines would take "paint code" and only pull up instances where the two terms are contiguous. Not this search engine. It means you get tons of articles you don't want, i.e. any article with thewhere words are not contiguous. When I use the search engine I waste tons of time because of this feature. For example, what if I wanted all articles about this "search engine" and it returns any article with the word "engine" in it. Quite a bit to wade through.
77 911, 3.0L
Old 07-17-2004, 03:31 AM
I think I've mastered ebay searches. I've got google search down pretty well too. I'm not sure about the best methods to use the search in Pelican forums however. Multi word phrases, two letter words, quotation marks - What works best?
I don't get any different results whether I do use the word "AND" or not between search terms. Caps or small doeesn't matter either. The FAQ section doesn't really explain how to search very well either.
I'd appreciate ay tricks on using the search feature!
Ken
Old 11-25-2004, 03:55 AM
Elombard's Avatar
This is a very good question, I have never been able to use it effectively. I know some people are very good at it but I cant see what they are doing. I thought I was an idiot :-))!
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 11-25-2004, 05:41 AM
I agree, for some reason I thought using quotes around 2 words brings back search results for those two words contigously...not just threads that happen to contain both words SOMEWHER in the thread. The quotes trick works perfectly on yahoo and google. Maybe Wayne could jump in here and clear this up. I ran into this trying to search for "top end rebuild".
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 11-25-2004, 07:50 AM
Dan Mc Intyre's Avatar
Elombard, you're not the only one! I've been searching this board for 6 months and I still can't figure it out.
Do quotation marks need to be used like: "paint and code"
Or just use it like this: paint and code
If I use the author's name, is there a special place for the name to go or just insert it in like this: paint and code and author
Any and all help will be appreciated!
77 911 2.7 Turbo Look
98 4-Runner
03 F-250 Power Stroke
93 Toyota P/U
Old 11-25-2004, 09:10 AM
Team California
speeder's Avatar
There is a box for the user/member's name in the search page. I have also found the search function to be maddening at times here; I have put in a word or phrase that is absolutely in the post or title and not gotten any results.
I then continue searching and eventually find the thread that I was searching for, and sure enough, there is the original phrase or word that I was using!
Maddening.
Denis
Old 11-25-2004, 09:21 AM
Elombard's Avatar
SEARCH PAGE -- what the heck are you talking about!!!
Oh there it is.....My goodness I never saw that before - no wonder.
Check it out guys this should help us:-))
Old 11-25-2004, 09:46 AM
LeRoux Strydom's Avatar
To search for two-letter words like SC, try using a wildcard: SC*
LeRoux
'90 964 C2 coupe (sold )
There are no old Porsches, only new owners.
Old 11-25-2004, 11:28 AM
OK. I've got it now. I just went to Google and did a search (with the quotes) for "Porsche 911 Technical Forum" "while the engine is out" and then click "repeat the search with the omitted results included". I got the results I was looking for about what seals I should replace while I have my engine out.
I feel stupid for not thinking of that before. - just use the google search engine on the related forum! I am much better at using that search engine and it has a few more options.
Problem solved!
Ken
Old 11-25-2004, 01:40 PM
