These things are like rabbits!...Made a few more this weekend and working my technique with increasing success.
Heres a pic with the jag cap. ![]() Aaron
Aaron. ![]() Burnham Performance https://www.instagram.com/burnhamperformance/ |
That looks yummy - I am interested even tho I have a 964 dual dist. setup. keep us all posted. This is a much needed item.
BURN-BRO my friend in corona california has and injection machine in his garage and mold making stuff I can set you up with him hes real smart and does this kinda stuff real CHEAP. Email me superjet.1@netzero.com
old911,I have an appointment with a plastic injection co. today. I will Email you asap, I like cheap.
Aaron
will this work on....you guessed it a 1980 911 SC? If so, I would definitely be interested...
Even if you just made the raw castings (could even be plastic), it wouldn't be that hard to get the finishing work done. TWM doesn't really have any competition that I see for <89 911s, which I'm sure influences their pricing. In other words, their stuff is pretty expensive.
Andy |
'75 911S 3.0L '75 914 3.2 Honda J '67 912R-STi '05 Cayenne Turbo '99 LR Disco 2, gone but not forgotten |
What kind of "epoxy" are you using for the prototypes shown in the pictures?
Aaron
Andy, While I was at the molder I brought up rsr velocity stacks. My old man has one for reference. A stack and throttle bodies sound like a fun project. I am giving it serious thought.
Aaron
Aaron
TWIN PLUG
YOU MIGHT HAVE A PROBLEM IN THE AREA OF ELECTRONIC HOLES GOING TO GROUND.IF YOU ARE MIXING A NON CONDUCTIVE MIXTURE ,LET IT CURE UNDER A VACUUM BELL (GLASS DOME).LET ME KNOW IF I CAN HELP.DON
Early on I did have a small(cosmetic) surface porosity issue in one spot . It has been solved through a mold revision. I have no issues right now. But vac may solve a borderline shot and reduce scrappage. Thanks for the input Don.
Aaron
twin plug
AARON,WHAT I WAS TALKING ABOUT WAS MICRO/HOLES THAT WOULD ALLOW A SHORT OR CROSS-FIRING NOT THE SURFACE.MIXING YOUR MIX YOU WILL TRAP AIR. JUST A PROBLEM I FACED WHEN I WAS MAKING PROXINIDY PROBS FOR PLANTS.DON
Got ya. I will look for that condition. Where you casting or injecting the probes with epoxy? Placing the mold in a vac for an 30 min until it sets up sound like a prudent plan.
Aaron
SSCenter - no need to yell, we hear you
Don I had caps on when I first joined. I didn't get it until someone told me. You are virtually yelling at the top of your lungs. Welcome aboard if no one has done so already.
TWIN PLUG
SORRY FOR YELLING!WHEN YOU GET WORKED OUT PUT ME YOUR LIST TO BUY.
O.K!!!!
Aaron
By yelling he means that you are using all caps. I'm sure everyone appreciates your help in making this a viable product that some can sell and others buy.
