jwmc1's Avatar
Got my compression check results
I got the compression results on my car, and they told me it was good...here are the results, what do you think?
PSI Cylindar
155 1
170 2
140 3
160 4
160 5
160 6
John
Old 06-04-2005, 11:38 AM
Nine9six's Avatar
John,
Who is "they"? Did you get leak down numbers for each cylinder as well? 30lbs of variance between cylinders on the compression...what do you think? How much oil does the car burn?
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 06-04-2005, 12:23 PM
Hi John:
Well sir, there are lots of opinions about results like these so one must consider the source,....
I'd be concerned about the # 3 cylinder.
I do not like compression testing for many reasons and I'd recommend performing a Leakdown test to confirm the above results and quantify WHERE the loss of pressure is coming from.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 06-04-2005, 12:25 PM
jwmc1's Avatar
Originally posted by Nine9six
John,
If this was such a big deal why in the world did you respond? I was simply interested in what others thought...I guess you must be having a bad day, go kick your dog.
John
Old 06-05-2005, 05:07 PM
Friend of Warren
Whoa, settle down there. These are valid questions. Did you do the compression test? A trusted friend? A garage? A leakdown test would go a long ways towards interpreting the numbers as would how much oil is being used/burned by the engine.
Kurt V
Old 06-05-2005, 06:27 PM
RETIRED
Joe Bob's Avatar
Somebody needs a valium and a BJ....
2012 ML350 3.0 Turbo Diesel
Old 06-05-2005, 06:31 PM
jwmc1's Avatar
They may be valid questions, but give me a break...who is "they" and "what do I think...it is 30 PSI apart" The guy was trying to be a jerk...and yes, I need a BJ, but who doesn't?
Burns very little oil and I did not have a leak down test yet, because they (my mechanic) is trying to get it running properly, since it is my understanding that you should not complete a leak down test until the engine is at proper operating temp.
John
Old 06-05-2005, 07:01 PM
Whew! That was fun....sort of.
-Steve
'87 Carrera Targa
Old 06-05-2005, 09:13 PM
MovOvr1's Avatar
I had my compression checked a year ago and the numbers were different like yours on one cylinder, but after a getting the engine warmed up (really warm) and then cooling it back down to regular temps, and doing the test the numbers were equal straight across. It could be a valve with a lot of build up that isn't closing..blah blah blah. My car hadn't been run in awhile and was in for the "spring cleaning".
Try it again when you do the leak down and the engine is run for a regular cycle and the carbon has been blown out of it.
Hope things work out....this is just my experience......and don't go kick your dog....he has nothing to do with it........
Brian
79 930
Brian
BLK 79-930
Old 06-06-2005, 06:50 AM
That is funny.
72T Coupe - SOLD :-(
Old 06-06-2005, 04:30 PM
