Got my compression check results
I got the compression results on my car, and they told me it was good...here are the results, what do you think?
PSI Cylindar 155 1 170 2 140 3 160 4 160 5 160 6 Thanks
John |
John,
Who is "they"? Did you get leak down numbers for each cylinder as well? 30lbs of variance between cylinders on the compression...what do you think? How much oil does the car burn?
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Hi John:
Well sir, there are lots of opinions about results like these so one must consider the source,.... ![]() I'd be concerned about the # 3 cylinder. I do not like compression testing for many reasons and I'd recommend performing a Leakdown test to confirm the above results and quantify WHERE the loss of pressure is coming from.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com Last edited by Steve@Rennsport; 06-04-2005 at 01:38 PM.. |
John |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
RETIRED
Somebody needs a valium and a BJ....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
They may be valid questions, but give me a break...who is "they" and "what do I think...it is 30 PSI apart" The guy was trying to be a jerk...and yes, I need a BJ, but who doesn't?
Burns very little oil and I did not have a leak down test yet, because they (my mechanic) is trying to get it running properly, since it is my understanding that you should not complete a leak down test until the engine is at proper operating temp.
John |
Whew! That was fun....sort of.
-Steve '87 Carrera Targa |
I had my compression checked a year ago and the numbers were different like yours on one cylinder, but after a getting the engine warmed up (really warm) and then cooling it back down to regular temps, and doing the test the numbers were equal straight across. It could be a valve with a lot of build up that isn't closing..blah blah blah. My car hadn't been run in awhile and was in for the "spring cleaning".
Try it again when you do the leak down and the engine is run for a regular cycle and the carbon has been blown out of it. Hope things work out....this is just my experience......and don't go kick your dog....he has nothing to do with it........ Brian 79 930
Brian BLK 79-930 |
72T Coupe - SOLD :-( |
