Designer King
Paulporsche's Avatar
For some of us I guess it's just "WE DON ' NEED NO STINKIN GAUGES!"
The car will tell you pretty much right away if you are in the right range w/ your setting. The same symptoms seem to come up on this board all the time. And that trick for finding the sweet spot is a handy "tool" in its own right.
I really have nothing against gauges. I also have nothing against someone taking the car to a mechanic for anything he does not want to do himself. Different strokes and all that.
Doug, I posted that question some time ago, and the responses I got from those who had used gauges and recorded the amount of change in % led me to the 8% figure, although noone had actually adjusted it as
far as 8%.
Since these cars will run (with varying degrees of success) with settings from 1% to 4% and 3-3.5 being what seems to be optimal, then if someone is getting that too rich idle hunting, then leaning by 1/16 increments shouldn't be harmful. If things don't seem right, you can always set it back.
And if you are smog exempt, who cares what your exact reading is anyway.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 07-28-2004, 07:47 PM
