Jim Smolka's Avatar
Assuming you are working with a Bosch O2 sensor wire, the 2 white wires are the heater wires, polarity is not important (12 VDC to one white wire, and ground to the other). The Grey wire is the ground (return) for the signal. The Black is the O2 signal wire.
A CIS fuel filter should be fine for your application
'75 914-6 3.2 (Track Car)
'81 SC 3.6 (Beast)
'993 Cab (Almost Done Restoring)
Old 08-02-2004, 12:20 PM
Senior Member
Ryan,
Where did you get the box used in the engine compartment for your wiring? Did you put the coils in there as well?
Joe A
Old 09-18-2004, 08:28 PM
warpspd's Avatar
Send a message via ICQ to warpspd
I used a C2 or a 993 fuse panel box. I mounted the coils on the
rear engine mount as they were stock. I had to bend the
bracket a little but it worked out fine...
Ryan
Cimarron region PCA member
98 Boxster
Old 09-18-2004, 09:22 PM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
to answer your fuel filter question...I have used the original ones for the past 18 months with no problems. I also foun an hydraulic shop that made some fittings for the fuel lines.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 09-19-2004, 12:40 AM
