19 years and 17k posts...
azasadny's Avatar
Missing tranny case to engine nut
Help!
I beginning to put my engine back in the car and noticed that I'm missing one of the 4 nuts that hold the tranny to the engine. Does anyone know what size the nut is that I need to get to replace it? I have a '74 with the 2.7CIS engine. Thanks!
Art Zasadny
Learning the bass guitar
www.ford.com
Old 08-02-2004, 10:29 AM
Gon fix it with me hammer
svandamme's Avatar
the stud should be M10 if i read the diagram right
if i remember correctly , the nuts are all identical , the studs are too , except one is longer for the startermotor...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 08-02-2004, 10:42 AM
Its 10mm Art
Ben
Old 08-02-2004, 10:43 AM
Banned
SteveStromberg's Avatar
Send a message via AIM to SteveStromberg Send a message via Yahoo to SteveStromberg
10mm x 1.0 mm pitch
Old 08-02-2004, 10:58 AM
KTL KTL is offline
Schleprock
KTL's Avatar
M10 it is. Nothing special about it. You should be able to get one at the hardware store.
Kevin L
'86 Carrera "Larry"
Old 08-02-2004, 11:01 AM
Vintage911Racer's Avatar
Send a message via AIM to Vintage911Racer
Nut
I did the same thing.
Mine however was 10 X1.50
Mark Scott
Vintage 911 Racer
1967 911S 2.4L ROCKET
Powered by Faragallah!
www.scottassociatesracing.com
Old 08-02-2004, 11:07 AM
azasadny's Avatar
Thanks!
Thanks! You guys are great!!
Art Zasadny
www.ford.com
Old 08-02-2004, 11:12 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
M10, course thread. The barrel nut that goes on the exhaust studs works well...
EDIT:
Chris B. pointed out an error in my statement:
The barrell nuts on the exhaust studs are 8mm, perhaps you are thinking of the 10mm head stud barrel nuts?
And Chris is dead on!!! The head stud barrel nuts will work.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 08-02-2004, 11:13 AM
Irrationally exuberant
ChrisBennet's Avatar
I think the transmission nuts are special or at least some of them are. They are M10x1.5 but instead of taking the usual wrench size (17mm) they take a 15mm wrench. The nut on the bottom, left side of the car needs one of these "reduced wrench size" nuts but I think the other 2 nuts can be "normal" ones.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 08-02-2004, 11:17 AM
If your patient you can use any of them but you are right they are special if you want to keep the car correct. I used standerd ones on my car except were the starter bolts up
Ben
Old 08-02-2004, 11:23 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Originally posted by Groesbeck Hurricane
M10, course thread. The barrel nut that goes on the exhaust studs works wel...
I think you mean the barrel nuts on the head studs, as in, the ones inside the valve covers? The exhaust studs are M8 x 1.25 threads.
Good catch Chris!!! I simply remembered what I bought from the hardware store to hang my motor on the stand. I forgot that those original nuts were thinner for clearing the transaxle case.
Kevin L
'86 Carrera "Larry"
Old 08-02-2004, 11:27 AM
