Hissing CIS intake
I have been trying to hunt down a little irratic idle. My car sounds like its an old mustang with carbs. So I tried raising the air plate so and the idle raised which leads me to believe that I am running rich. Anyway when I removed the intake boot I heard this air hissing sound coming from the air box. I was wondering what this could be and how I could further diagnose this problem.
Think Intergalactically Act Interplanetarily
Old 08-09-2004, 10:25 AM
I apologize its not the intake boot but the cone shaped intake that holds the air filter to the intake.
Old 08-09-2004, 11:52 AM
Designer King
Paulporsche's Avatar
Did you try leaning the mixture slightly?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-09-2004, 02:08 PM
RETIRED
Joe Bob's Avatar
Take some carb cleaner....LIGTHLY spray near areas that might leak....change in idle you found the leak. Kep yer head out as much as possible unless you like the smell of ether....or you were a buddy of Ricahrd Pryor.....%^B
2012 ML350 3.0 Turbo Diesel
Old 08-09-2004, 02:23 PM
Unfortunately I do not have a gas analyzer so I have not yet taken the jump to try and adjust my mixture. I was just going to take careful notes of the amount that I am turning the mixture adjustment screw and give it a go. However it is tempting to take it to a shop. Does anyone know approximately how much it would be to have a Porsche shop do a mixture adjustment. Also I am assuming that I should have the mixture adjusted before I get it smoged. Is this correct? Thanks for your help.
Old 08-09-2004, 03:37 PM
RETIRED
Joe Bob's Avatar
Whatever the minimum is....like 1-2 hours @ the base rate....65-100/hour. Bring a bottle of Jack Daniels....be friendly.
Old 08-09-2004, 03:40 PM
