LinkBack | Thread Tools | Rate Thread |
Hi - I'm in the processs of removing the rear blower - converting to earlysystem- SSI's already in place and I have the two triangular metal pieces that bolt on each side of the fan shroud that the hoses attach to -
http://www.pelicanparts.com/catalog/shopcart/911E_catalog.htm But I can't find it Also there is a part list for the conversion I can't tell what these parts are and if I need them all -0 surely I just need the two pieces I've got??? I want to check before starting so the car isn't laid up.. Please advise Cheers - Tony
TSwede |
~Thanks.... Can I just ask though..?
Does anyone know what these bits are
x 4 plastic nuts, 999.591.592.40, list $.25 each x 2 rubber plugs, 999.703.044.50, list $.77 each x Right engine cover plate, 911.106.036.00, list $14.89 x Right engine cover, 911.106.827.00, list $5.04 x Right air duct support, 911.106.331.00, list $1.30 I have the 2 ducts.. and some hose.... What are these other bits?? Any pics anyone?? I phoned the Porsche garage and they were unable to cross reference these numbers to their diagrams system to help me...
TSwede |
where did you get the triangular pieces ?
my life begins at 150MPH |
RE: Triangular pieces
I got them at ninemeister in the U.K.
TSwede |
disband
you may not need the entire parts list on your 75. i just did my 78sc and did not need many of the parts shown on the parts lists. the rightside portion off the fan shroud i did need all of that. i did not need all the tin that runs along the valve covers, or the two small "hole" pieces that allow the hose to run through to the exchangers. the stock left side piece off the fan shroud i did use, but i could have bushed down the original one to accept the hose that runs to the exchangers.
heat backdate install direction there is the last of my threads on the job. notice the parts in the exploded view
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft Last edited by car 311; 08-09-2004 at 02:55 PM.. |
I just did this on my 76 and I only needed the two triangular plates you describe as already having. The replacement pieces for the engine tin are not necessary and neither are any of the special screws, nuts, plugs, etc. described in the parts list above. The hardest part about this project will be fitting the driver side plate to clear the distributor.
re: side plate clearance
I got a left side plate off a Turbo - apparently it has the required clearance..
TSwede |
