Sleep Deprived and Grumpy
Replacing the Front Calipers:?
I have to replace my front calipers and damn those 2 bolts are on there.? Any suggestions? A little heat? Or just keep cranking on em?
Any advice? Jon |
Somewhere in the Midwest
I use a breaker bar.
Alright.. Thats what i will try to do here in a bit! I have an old pipe i attach to a wrench or socket that usually does the job. But... My first attempt didnt go so good
I would rather be driving
I have bumped my breaker bar with a dead blow hammer before. This usually works great.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
I will give it a shot later today!
Wish me luck! Jon |
Jamie is right. A little shock from a steel hammer (forget the rubber mallot..it don'ta do a no goot!) will be just enough to break the corrosion fused surfaces.
Would it hurt to put some wd 40 or other penetrating oil?
Thanks Dan
Dan |
Guest
Posts: n/a
PB blaster and a dead blow BFH worked for me.
Make sure you use a six point socket!
PCA-Chicago Region-DE Tech Coordinator-Retired PCA-Chicago Region GingerMan DE Co-Chair-Retired 1987 Cab-under construction-Sold pending pickup 1986 911- Race/DE car-Sold |
Probably not a recommended procedure, but I had one bolt I could not get unstuck by banging, penetrating oil or anything else. I used a breaker bar with the shortest socket I had. I positioned the bar parallel to the garage floor and put my floor jack under the end of the bar. Though it was nerve racking and almost lifted the car off the jack stands, the bolt finally turned.
Not for the careful, cautious or the faint of heart.
Parkin Hunter 80 911 SC Targa Charlotte, NC |
