In the shop at Pelican
Jared at Pelican Parts's Avatar
Making your own A/C hose....
I have been going over what's involved in getting the A/C to work on my A/C and have looked at the cost of replacment lines..
There's gotta be a way to find some hose that can handle the pressures of A/C systems...
What I'd like to do is find some, cut it to length, then cut the fittings off the old hose, clamp them onto the new hose..
Anyone know what properties the hose has to have, and where I might find some?
Old 08-30-2004, 12:09 PM
B D B D is offline
B D's Avatar
Jared try calling a hose shop and they will be a great resource. There is a nice small shop called Mesa Hose off 17th in Costa Mesa, bring in the old hoses and clamps and they will recreate them with new hoses and possibly new clamps/fitttings.
68 911L
Old 08-30-2004, 12:13 PM
I was thinking more about buying hose in bulk....
gettign the A/C to work cheap is the operative word....
Old 08-30-2004, 12:14 PM
I found this link:
Hose
Hope this helps.
Andrew
Old 08-30-2004, 12:38 PM
Exactly what I need.... thanks...
Old 08-30-2004, 12:40 PM
B D B D is offline
B D's Avatar
That's usually what I do, I just bring in some sample hose and buy it in bulk and make my own replacements at home.
68 911L
Old 08-30-2004, 03:01 PM
How much does barrier hose run a foot, anyway?
Old 08-30-2004, 03:02 PM
Thread Killer
Teutonics's Avatar
ackits.com (at the link above) will make an entire set of new barrier a/c lines with new aluminum (won't rust) fittings for ~$120 including shipping! They also throw in a complete set of O-rings and compressor oil.
For that price I didn't think it was worth the hassle...
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 08-30-2004, 04:24 PM
That is pretty good. Do you have to give them all the dimensions and sizes, or do they already have them for the 911?
Old 08-30-2004, 04:26 PM
Senior Member
Jared,
AcKits is the best I have found in years. What I did was to take them the old fittings and they reused them on new hose.
They left one end off so I could snake the new hose around in the car and then had it crimped after the hose was in place. As long as they have a fair amound of room they can crimp one end on with no problem.
They also have a very good forum for A/C questions or just call them directly and they have been very good in helping.
Joe A
Old 08-30-2004, 04:43 PM
WHat im thinking of doing is ordering the hose in bulk and just cut and crimp as I need to...
Old 08-30-2004, 04:44 PM
Regular crimping dies (as used for hydraulic lines or fuel lines) will overcrimp A/C fitting ferrules and cut into the hose possibly resulting in leaks. Jim
Old 08-30-2004, 05:06 PM
Decolliber's Avatar
Don't a/c hoses have teeny tiny little holes so that if pressure builds up the hose does not burst? Somene told me thats one reason why you lose refrigerant over time.
John C
1988 911 Carrera coupe
2002 BMW 530
Old 08-30-2004, 05:53 PM
Thread Killer
Teutonics's Avatar
I sent them all of my old hoses, and they sent me new replacements. I didn't find that having the fittings already on the hoses made running them any more difficult.
They may have the dimensions already... If you can find someone that has already had theirs done, they should be able to pull up the invoice to get all of the sizes and fitting information. You're welcome to use mine, but it's from a Carrera with O-ring fittings. If you think it will work for you, send me an email or PM and I'll send you my information.
Allen
'85 911 Coupe
'75 BMW 2002
Old 08-30-2004, 07:33 PM
Designer King
Paulporsche's Avatar
JohnC,
The old hoses, for freon were as you describe. The new hoses required for the new refrigerants are "barrier hoses" which are not porous and do not leak.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-30-2004, 08:17 PM
If one has to pass an A/C hose into the engine compartment up through that slot ahead of the shock tower not having a fitting on the end of the hose is a real advantage.
Old 08-30-2004, 08:20 PM
KobaltBlau's Avatar
Jared, search for posts by "fred cook" on this forum, he has done this also and is pretty resourceful.
Andy
Old 08-30-2004, 09:28 PM
