ecm911's Avatar
Installation Of engine mount console ?
First I have never done nor seen or read about this . Tried doing some searches, but to no avail.
I am replacing because of an accident. The impact in the drivers side rear. Among other things, the engine support bar and the console( mounted to engine) that it is mounted to were bent.
I took some force to get the console of the engine, two of the four studs were bent ( Top left and bottom right) . I replaced both of these and when I go to mount a new console to engine I can't get it over all of the struds.
I pulled the remaining stud at the bottom and will replace ( part on order). But the last stud ( smaller in top right) sure looks straight to me and beside I could not get it to budge ( I order it anyway).
The question - how easy should the installion be. Line and bolt it on? If so, then I will bite the bullet and replace the last stud. Or is there a trick? As you can tell, I am very nervous removing studs that I can budge- this one is a 10x15 so not a lot to work with. AND it is on the engine - ^%$#@!.
Earl
Old 08-10-2004, 08:57 PM
Re: Installation Of engine mount console ?
huh!
you have the elec console mounted on the engine?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-11-2004, 12:07 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
huh? Are you talking about the engine tin?
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 08-11-2004, 04:10 AM
ecm911's Avatar
Sorry, let me try to clarify.
Not the engine tin.
It is what the engine support bar mounts to and it is covering the pulley. The PET calls it a mounting console.
Earl
Old 08-11-2004, 06:15 AM
your model & year in the signiture area saves me asking.
anyway, pick a number..
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-11-2004, 06:44 AM
Hey why is that shock absorber in there any way?? I have the older style on my 3.0 in my 77??
Ben
Old 08-11-2004, 06:54 AM
Shock 13 and associated gear is used for Cabs .....
---Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-11-2004, 07:11 AM
ecm911's Avatar
Robin,
You got it. Number 20. I replaced studs # 26 ( two of them).
There are two other studs not shown here - top right (smaller one) and top left ( much larger & has been replaced).
Earl
Old 08-11-2004, 07:30 AM
It should slide right over the studs, so either the studs or the "console" or both have problems.
The #26 you cite is the washer going underneath the bolt that attaches the bowtie-shaped engine mount to the console. The studs that mount the console to the engine case (the ones I think you're talking about) aren't shown in RoninLB's picture.
Old 08-11-2004, 08:14 AM
ecm911's Avatar
Thanks,
I know what I have to do now. Appreciate the response.
Earl
Old 08-11-2004, 08:16 AM
LOL
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-11-2004, 08:34 AM
ecm911's Avatar
Ouch!
I am so dependent on spellcheck!
Old 08-11-2004, 08:38 AM
