73911guy's Avatar
"High output alternator" from Australia
Is anyone using one of the "High output alternators" made in Australia that Pelican and Aase are selling? Bruce A has commented that they are made from Bosch components and reliability should be higher than the Marchal / Motorola OEM models.
I'm looking for some feedback - I'm tired of replacing internal voltage regulators on the Marchal unit I've got.
Jim
Old 08-11-2004, 07:38 AM
der Mond's Avatar
Aussie Alternator
Jim,
I installed one a couple weeks ago in my '87 Carrera non-turbo. Before I did, I had it bench tested by an alternator specialist/rebuilder here in Fairbanks who said it does what it says and looked good. It makes just a tad more stator noise under load than the used French Valeo OEM-style one I took out. Seems to work just fine with about 700 miles on it. I put out a message like yours a month ago and received a PM from the builder at http://k3.com.au/ which was thoughtful. He said the unit comes with instructions, a new light bulb for the ammeter gauge and an adapter since the battery terminal on the alternator is larger diameter than the wiring connector on my car. Unfortunately, the unit, which was "rush" shipped direct from K3 through Pelican, had no instructions, no light bulb and no adapter. There are instructions on the K3 website. They spec soldering the new connector, but the adapter is supposed to eliminate the need to do that. I was in a pinch so decided to make my own adapter by drilling the two different sized holes in a piece of thick metal strap and bending it to fit just right. The unit also came with longer than OEM through-bolts necessitating that I file away about 3/8" of the plastic from the cone that fits over the alternator to allow getting one of the nuts on the through bolt. Also, there were no nuts supplied for the through bolts, so I needed to go to NAPA and buy 6 5 mm nylon-insert stop nuts and washers, and extras just in case. The through-bolts also were slightly bent when I unpacked the unit, but not enough to be a problem. One last thing - during installation, I discovered that the terminal on the alternator for my blue wire connector was also larger diameter, but I was able to successfully split the connector with wire cutters and spread it enough to get it over the terminal without breaking it, and put an extra washer over it. The upshot is that the alternator did install finally, put out good juice from the start and seems fine, so I am hopeful. I emailed my concerns to Pelican, and Wayne replied immediately and said his importer would discuss it with Geoff Easton at K3 to try to resolve it. I also emailed same to Geoff but have not received a reply. As it stands, I'm not entirely sure I have the one-year warranty which comes with the unit. Geoff likes to have the fan ring number, visible on top, to make sure the new unit fits the particular fan ring for the car properly. If I had not asked for a rush order and had given the fan ring number to K3 in advance, perhaps none of this would be an issue. The unit is also supposed to come with all necessary electronics to adapt from external to the internal regulator as well. Another nice feature is the Zenner diode rectifier plate, which, I was told, eliminates the notorious overcharging issue when the regulator wears out. The unit would ostensibly just quit charging and the ammeter light illuminate. Since thus far the alternator itself seems worth a shot, I would recommend you talk with Pelican and K3 and see if your experience can be trouble-free. I got no feedback from anyone on Rennlist, Pelican or Porsche_911@yahoo from anyone with experience with the unit. I am hoping that my feedback will pave the way for others to give it a try and share how well the unit works for them.
(Dennis H.)
Peace & Thanks,
der Mond
'87 Carrera Coupe
Venetian Blue Metallic
Old 08-11-2004, 02:59 PM
73911guy's Avatar
Thanks for the response, Dennis.
The last time my voltage regulator went out (the internal one on the Marchal unit) it took out my ignition system leaving me stranded. It fried the Mallory unit by sending 18 volts (verified at alternator rebuild but I'm getting ahead of myself) continously through the coil, which boiled the oil out of the coil. Thinking it was an ignition box problem, I bought another one and it took the alternator 15 minutes to fry the new ignition and leave me stranded exactly one mile from home. I didn't realize it but the hill 2 tenths of a mile from my home is pretty big when you are the only one pushing. So now I was out $$$ for the ignition system, had to spend $$$ for another on top of having the alternator rebuilt. So if the feature you mention where the alternator will shut down if the VR fails sounds good. I'm looking for more feedback - hopefully PP wil chime in here and give some success stories.
Thanks again.
Jim
Old 08-11-2004, 05:03 PM
der Mond's Avatar
"High Output" Alternator
Geoff Easton from K3 contacted me after reading my above post - he never got the email I sent him after installation and seemed genuinely surprised and sorry that the unit arrived as it did. He assured me I have the one year warranty. So, again, the alternator seems to work fine and that diode insurance is a good feature. I'd encourage folks to just talk with both Pelican and K3 before finalizing the order, because I assume this squeeky wheel may result in a more reliable system being worked out, and it may be a valuable alternator alternative for we 911 lovers who don't want to be subconsciosly waiting to smell an overcharging battery.
Peace & Thanks,
der Mond
'87 Carrera Coupe
Old 08-12-2004, 10:19 PM
Lorenfb's Avatar
"Bruce A has commented that they are made from Bosch components and reliability should be higher than the Marchal / Motorola OEM models."
I can't believe that BA made such a statement without any real data.
More reliable - NOT, probably total B.S and marketing hype!
"Another nice feature is the Zenner diode rectifier plate, which, I was told, eliminates the notorious overcharging issue when the regulator wears out."
There's no way you can RELIABLELY assume that zener diodes are capable
of limiting the voltage output of an alternater capable of a 90 amp output.
The overcharging alternator will "take-out" the zener diodes in no time.
This is just marketing hype!
"So if the feature you mention where the alternator will shut down if the VR fails sounds good."
If this is another/added circuit, then this adds to reduced reliability of the alternator.
So what happens if the new circuit shuts-down the alt. prematurely or fails to function
when needed.
Just buy/rebuild the OEM Porsche alternator and avoid replacing two alternators in
the short term. It'll be cheaper in the long term, e.g. the price is ridiculous.
If you want inceased alternator reliability, then place the regulator externally
from the alternator.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 08-13-2004, 07:44 AM
der Mond's Avatar
Loren,
It appears that I am the sole public guinea pig for this unit so will report how well this empirical trial goes. Can you explain (as Denzel Washington said in "Philadelphia", tell it to me so a sixth grader could understand it) how switching to an external regulator would improve reliability? Thanks.
Peace & Thanks,
der Mond
'87 Carrera Coupe
Old 08-13-2004, 10:24 AM
External regulator would not be subject to the same (high) heat of an internal unit...especially under a shut down and "hot-soak" condition.
--Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-13-2004, 03:20 PM
Lorenfb's Avatar
Wil said it all!
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 08-13-2004, 10:21 PM
I was told that the newer style external reg transistor unit is "cleaner" on the elec system than the old style traditional reg.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-14-2004, 12:01 AM
Lorenfb's Avatar
"I was told that the newer style external reg transistor unit is "cleaner" on the elec system than the old style traditional reg."
What?
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 08-14-2004, 09:36 AM
Randy Webb's Avatar
Cleaner? I bet Ron means it rectifies the a/c voltage better so there is less riplle to deal with.
Ron, can you edify us??
Old 08-14-2004, 12:32 PM
Thanks again Randy.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-14-2004, 12:35 PM
oh yeah.. I was told is the mechanical points can cause elec line problems.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-14-2004, 12:41 PM
Originally posted by 73911guy
The last time my voltage regulator went out (the internal one on the Marchal unit) it took out my ignition system leaving me stranded. It fried the Mallory unit.....................
To avoid additional damge (frying the ignition!!!), what is the opinion/recommendation as far as replacing the regulator. What I mean is that I do not have any issues replacing a functional/working unit as a maintenance item. I do not want to wait for this unit to fail causing more problem.
Old 08-14-2004, 01:55 PM
imo install a voltmeter.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-14-2004, 03:54 PM
Randy Webb's Avatar
Well. I wouldn't worry too much w/o seeing some actual data on this.
Hot air rises, so the ext. reg. may get just as hot as the internal one. If you wnat to know the answer, you will measure air temps at the 2 locations with Tcpls. Also, the alt. and int. reg. are right in the air stream from the blower. Third, the int. reg. is a newer design and may well be more robust.
What you see above is specualtion - informed maybe, but not a conclusion drqwn on data. You may as well do what many thousand of 911 drivers do about this -- nothing. Or put in a volt meter if you want.
Old 08-14-2004, 04:07 PM
Lorenfb's Avatar
"I bet Ron means it rectifies the a/c voltage better so there is less riplle to deal with."
All alternators are three phase A.C. generators, where the ripple frequency is
three times its RPM. Unless the alternator has an additional phase, the ripple
is the same for all alternators, i.e. in the millivolts. The rectifier diodes have
no effect on the ripple.
The way the regulator operates, though, once the regulation voltage is reached,
does affect the ripple. Most (all) regulators operate as on/off switches to the field
current. This is because if they operated as linear regulators, they would dissipate
too much heat.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 08-14-2004, 04:31 PM
Originally posted by Lorenfb
"Most (all) regulators operate as on/off switches to the field
current. .
so dirty mech reg points would affect what? AC ripple?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-14-2004, 04:53 PM
Randy Webb's Avatar
I'm talking about the ripple at the output of the regulator.
Old 08-14-2004, 05:20 PM
Lorenfb's Avatar
There's no ripple at the regulator output. The alternator regulator is NOT like
an electronic I.C. regulator which has an output ripple spec. An alternator
regulator is just an on/off switch to "tell" the alternator to charge or not to charge.
The car's electrical system just "sees" the alternator output which is essentially
"filtered" by the battery.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 08-14-2004, 07:16 PM
