Thack's Avatar
Send a message via Yahoo to Thack
CIS runs badly when warm up
My 79' 911SC runs poorly when up to operating temp. I suspected the freq. valve and the sensor plate. When the car was cooled down it ran well but when warm I have to pump the gas and floor it to get it to run, then it only runs well above 4K RPM. Should I look now at the WUR?
Mike
Old 08-12-2004, 12:37 PM
Otto's Avatar
cis
There has to be someone in your area that has a set of fuel pressure guages that can test the fuel pressure both hot or cold. It sounds like a chech valve problem.
Racing Porsche for over 30 years.
http://www.OttosVenice.com
Check out the Porsche Owners Club Track event Videos
Old 08-12-2004, 01:55 PM
If you're going to try to deal with it yourself you MUST have CIS test guages. Otherwise youl'll be replacing the wrong parts. It's the best investment you can make.
Old 08-12-2004, 02:00 PM
Forgot to mention that you'll also need a Bosch CIS book.
Old 08-12-2004, 02:01 PM
Designer King
Paulporsche's Avatar
Sounds like the WUR. You can check the warm control pressure w/ the gauges the others have mentioned.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-12-2004, 02:08 PM
