Carrera Fog Lights... Better alternative?
I have two broken ones and I was going to replace these but I got thinking...
(1) Amber or white? (2) Replace with Hellas (or other brand) or stay with "factory"? (3) Replace with driving lights instead? Any recommendations?
the odd Porsche here and there |
I have driving lights up front and they're just as useless as the foglights were....IMO.
Warren & Ron, may you rest in Peace. |
Or...Hella 450's ...with slight mods to fit...the length and width are nearly OEM, and you can get these in driving or fog-light lens styles.
---Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Buy some cheap driving lights from Western Auto or Pep Boys, they are some brands that looks like the factory driving lights and the installation process are the same without no modifications. I installed one aftermarket diving light kit (by owner request) to a Porsche 911 because some object in the road hit one factory driving light and is too much money to pay for something that can be broken again.
1972 911T 1991 Mazda RX-7 Turbo II Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life! Last edited by Nitrometano; 08-18-2004 at 08:23 PM.. |
I've had both of mine taped up with black tape for at least 5 years 'cause they were taking rock hits at least once a year. IMO they are worthless unless you drive at night in the country. I've thought about replacing them with air ducts to the brakes or maybe (as suggested above) with something from Pep Boys.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
Brake cooling ducts ...
George M '89 Carrera 3.2 '91 928GT '76 914 '18 Macan GTS |
Another view
I've got Hella FF200s on mine. They're not 'correct' or even the right shape, but the standard lights just don't put enough light on the road for my taste.
![]() I just replaced one last weekend (I think I hit the dip at the end of a driveway too fast). I hated being without it.
Dave '77 911S Rochester, NY |
I use a Stoneguard prod for my headlight lens. It's about 1/4in thick. Pelican Parts made the specific call on which pn would fit my lens. I can only guess that they can find Stoneguard for the fogs.
fwiw, the headlight lens protectors were a bit oner $20.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
