JohnS_77's Avatar
Send a message via Yahoo to JohnS_77
[Turn signal switch] Where does this wire go?
I'm almost done with installing my new turn signal switch. I used great caution when installing the wires on the headlight on/off switch by taking one wire off, putting the new wire on before going to the next wire.
However, do you think I can remember where this last wire attaches? No, I cannot! It is a brown wire, and it looks like it comes from the wiper switch on the RH side of the steering column. I assume it is a ground wire, and attaches to the metal "frame work" that hold the clam shell covers around the steering column. I have attached two pictures.
Maybe somebody could show a picture of theirs assembled? It would help out a ton!
THANKS!!!
Old 08-16-2004, 03:40 PM
to ground, on the lower right screw hole in the picture. put the upper and lower plastic housings on first.
206 637 4071
Old 08-16-2004, 03:49 PM
JohnS_77's Avatar
THANK YOU!!!
1985 911 Targa
1977 Corvette
1997 VW Cabrio
1998 Saturn SC2
1999 Chevy Venture Van
Old 08-16-2004, 03:53 PM
