[Turn signal switch] Where does this wire go?
I'm almost done with installing my new turn signal switch. I used great caution when installing the wires on the headlight on/off switch by taking one wire off, putting the new wire on before going to the next wire.
However, do you think I can remember where this last wire attaches? No, I cannot! It is a brown wire, and it looks like it comes from the wiper switch on the RH side of the steering column. I assume it is a ground wire, and attaches to the metal "frame work" that hold the clam shell covers around the steering column. I have attached two pictures. Maybe somebody could show a picture of theirs assembled? It would help out a ton! THANKS!!!
to ground, on the lower right screw hole in the picture. put the upper and lower plastic housings on first.
1985 911 Targa 1977 Corvette 1997 VW Cabrio 1998 Saturn SC2 1999 Chevy Venture Van |
