Tach problems
I have an 89 911. The tach quit working. I pulled the tach everything looks plugged in, however there are other wires behind my gauges hanging there loose. The car in unmolested with only 11000 original miles. So I doubt anyone has messed with the wiring. Any help on the tach would be appreciated. Also, just completed my first valve adjustment, thanks to all who answered my questions, and built up my confidence.
Old 08-19-2004, 02:24 PM
Location: member Central PA Region PCA , Home of the Hershey Swap
Can you post a picture of the wires and tach back side, while plugged in?
If it's toast, I had a good experience with North Hollywood Tach and Clock.
regards,
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 08-19-2004, 02:47 PM
Designer King
Paulporsche's Avatar
Maybe your connections are just oxidized. Try cleaning and recrimping.
Is there a fuse for the tach?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-19-2004, 04:04 PM
Lorenfb's Avatar
"I had a good experience with North Hollywood Tach and Clock.
regards,
Steve"
You might call Pelican next time as they have many sources for rebuilt parts.
Have Fun
Loren
Systems Consulting
Automotive Electronics
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 08-19-2004, 06:23 PM
I don't have a digital camera to take a picture. I didn't see any inline fuses. All the wires look clean with good contact. ?????????
Old 08-19-2004, 06:46 PM
Lorenfb's Avatar
The tach wire on a 3.2 goes to pin 21 on the DME unit. Use an ohmmeter to check
for continuity. Then check for ground and +12 volts on the other pins of the tach.
Have Fun
Loren
Systems Consulting
'88 911 3.2
'04 GSXR1000
'01 Ducati 996
'03 BMW BCR - Gone
Old 08-20-2004, 08:17 AM
