Hi All -
I noticed a slight oil leak/drop on my '87 Carrera. On further inspection, I saw that the upper-left-hand bolt on the right-side upper chain ramp (the bolt that is accessible externally on the case) had loosened to the last few threads. I tightened it up, but I am wondering if: a) anything was damaged b) the timing is off c) if I should do anything else? There were no strange noises or any problems other than the leak.
1987 535is, 1966 GTV, 2015 F-Type R, 2013 991 C2, 2011 E550c, 2007 997 C2S, 1987 911, 1958 356 1600s, 1956 356 1600s |
Anyone? Please?
Seth,
If all it did was back out a couple of threads ... no problem with the ramp, as it has quite a long shoulder that 'captures' and locates the ramp! It certainly wouldn't hurt to order a new set of ramps and gasket kit, plus the oil lines, sealing rings, and ferrules ... and plan to replace everything, as the plastic ramps do get brittle with age, and old oil lines to the heads and tensioners tend to leak after being disturbed.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' Last edited by Early_S_Man; 08-29-2004 at 07:05 AM.. |
