Ballast unit missing
With much thanks to Early S man I know know why my tach doesn't work. No ballast unit. Anybody know where a ballast unit for a 1971 2.2T can be had. Does our host have them. Is there a substitute? Can one be fabricated. I'm sure it is some kind of big resistor.
Steve F
69 911
71 911
87 Carrera
2004 RAM 1500 4x4 "Hemi"
Old 08-29-2004, 03:07 PM
bump... anybody?
Steve F
69 911
71 911
87 Carrera
Old 08-30-2004, 09:31 AM
Bird. It's the word...
Fishcop's Avatar
Okay, I'll go out on limb... I'm fairly sure any 12 volt ballast resistor will do the job. They should be available at automotive supply shops. I replaced the original in my car when I upgraded to a Crane XR700. It came with the Crane coil. It looks very different to the original Bosch being ceramic as opposed to the Bosch alloy and epoxy. I suspect the price will not be too much and not worth fabricating your own.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 08-30-2004, 06:02 PM
Zeke's Avatar
Where is the thing?
Old 08-30-2004, 10:49 PM
Fishcop's Avatar
On my 69 I found it on the left side of the engine bay with the relays.
John Forcier
Old 08-30-2004, 11:37 PM
Fishcop's Avatar
Oops, I have been corrected and informed there are two different kinds, one for the primary coil and another for the tacho... So please ignore me
John Forcier
Old 08-30-2004, 11:54 PM
Early_S_Man's Avatar
Porsche Crest
There are actually three ballast units available ... all are three-terminal resistive dividers, all have three 'pigtail wires' with terminals on them, and are all mounted on the relay plate/panel!
For battery-coil ignitions, there are two, both are shallow rectangular boxes:
Beru ... 901.602.852.00
Bosch ... 901.602.853.00
For CDI ignition, there is only one, and it is cylindrical, aluminum can, taller than a round relay ... 901.602.601.00
The CDI and battery-coil devices aren't interchangeable, and I don't have the resistance values.
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-31-2004, 08:52 AM
