release fork "problem"
While trying to remove the clutch release fork from my G50 transmission so I could split the engine & tranny I managed to snap the bolt I threaded into the cross-shaft right off (just inside the needle bearing.) Before I make a bigger mess does anyone have any suggestions? My Craftsman bolt extractor drill bits have not worked and I can't weld anything to the bolt (would JB Weld work?)
Schleprock
Drill out the snapped screw altogether with incrementally larger bits until you can reopen the threaded hole. If unsuccessful at reaching clean threads, then drill and rethread to the next size bigger if possible.
Don't bother with JB Weld. I think that stuff blows. Are you updating the cross shaft or has the update already been done? If the update hasn't been done, then the old shaft is most likely garbage. Can you weld a new, bigger screw to the shaft itself? Replacement updated OEM Porsche shaft isn't all that expensive @ just under $40.
Kevin L '86 Carrera "Larry" |
