Need the light insert for a '70 pullout dash knob
O.K., guys I'm getting a little esoteric here, but try to work with me!
On both the rear defrost and foglight knobs on the dash, when you pull them out there is a tiny light that illuminates in the center of the knob. This light works by illuminating a little tiny plastic piece (1/8 inch wide, about one inch long) that inserts into the center of the axle that the knob screws onto.
So here's my question: Who has an extra one of these little plastic pieces? They are clear, with a little colored dot on the end.
Anybody out there have one they can throw my way? Best regards to all.
Rob
1997 993TT
1973 Carrera RS #1334
1970 911S sunroof coupe
'99 MBZ E55
1999, 2001 & 2003 daughters!
Old 09-04-2004, 10:36 PM
Designer King
Paulporsche's Avatar
Rob,
I don't have one nor have I actually seen one, but judging from your description it sounds like an early example of fiberoptics. Maybe a piece of plastic from a hobby shop or your local plastics supplier can substitute. You may be able to color the end w/ a marker (alcohol base) or some paint used by hobbiests to simulate stained glass, or even find a colored piece of translucent plastic (like acrylic).
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-05-2004, 05:43 AM
