Senior Member
Jdub's Avatar
Venting air to the trombone cooler part two.
I have cut the rightside front bellows piece and fabricated a 90degree 3" mouth scoop to direct air to the trombone cooler. The scoop empties the air at the front rightside of the cooler so that ought to help things.
However, I still want to punch a hole in my non-foglight valance to get more air into the rightside fender area, which is typically a dead zone, air-wise. Taking directions from some Pelicanites, I am fabricating a blocking plate that will run horizontally from the valance lower lip directly back to the trombone cooler, mounting on the lowermost hoop curve via a hose clamp. A 2" "flip" to the metal will direct air up the backside of the trombone cooler without interfering with the tire. This blocking piece is in essence a director as it prevents air from emptying under the car and instead forces the air from the hole in the valance (3 or 4", unsure which size to go...) past the trombone cooler.
Other than telling me to shell out the buck for a Carrera cooler, does anyone have any words of wisdom about how else I might force air through the righside inner fender and past the trombone cooler? Would the hole in the valance be more effective if I ducted the stream more directly to the cooler? I cannot make a shroud for the cooler, but can use "necked" semi-rigid plastic ball and socket hose and a rectangular open mouth end (think vacuum cleaner attachment only bigger) to point the air from the valance hole to the cooler. This can be repointed any time since it is very rigid and stays in place once set.
Pics to come - many thanks to those who have labored to understand this Quixotic mission!
Tilting at windmills,
John
PS: What is the horn relocation kit? Anyone have an alternative location for my dual horn setup with the longish trumpets to them?
'78 Targa in Minerva Blue
Old 09-07-2004, 08:19 AM
Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
buy a Mocal cooler. LOL
You are only going to gain so much with the trombone, as you need to increase the surface area containing the oil and allow the air to cool it better. Have you considered installing the lines from Elephant racing? This will assist you and allow you to keep the trombone if that is what you prefer.
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 09-07-2004, 08:46 AM
Senior Member
Jdub's Avatar
I understand where you're coming from, but the price is too dear right now, and with winter coming I can save my pennies for the right setup.
For now, I want to experiment and see what I can do. That's why I am continuing on this course.
Many thanks,
John
Old 09-07-2004, 08:48 AM
Montana 911
k9handler's Avatar
JMPRO (I think that's his username) sells a scoop that installs in place of the reflector, this little scoop pulls in pretty good airflow into the space where the cooler is...or you could fab up something similar.
H.D. Smith
2020 Yamaha YFZ450R
Old 09-07-2004, 08:51 AM
banjomike's Avatar
If you're gonna use a 'hose' to direct air maybe you should direct it at the oil lines running along the top of the wheel well. That way you'll have parrallel flow and you'll get cool air to a greater length of "cooler".
Mike
Searching for a new ride
'04 VW GTI 1.8T RIP
'76 911S 3.0 RIP
http://www.pelicanparts.com/gallery/BanjoMike
Old 09-07-2004, 08:58 AM
Me like track days
Craig 930 RS's Avatar
Really stick with K9handler's advice - I've been down this road and you are truly (strong words coming....) wasting your time with the trombone cooler -
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ -
"930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe
Movie: 930 on the dyno
Old 09-07-2004, 10:29 AM
mark_d_mcguire's Avatar
I'll second the comments, if your car is too hot with the trombone, you will never be able to make it better without replacement.
I tried it all, scoop, holes in the valence, removing turn signal. Nothing worked. Upgraded, never get over 200 now.
Don't know what your budget constraints are, but there is a new carrera cooler for sale on ebay right now, check out Item number: 7920037471.
There is also a used one listed now as well.
Good Luck!
Mark
H Class Race Car Project
Old flames: 1999 C2 Race Car #78; 1983 SC Race Car; #78; 1990 C2; 1978 SC Race Car #78; 1988 Carrera; 1977 911S
Old 09-07-2004, 02:15 PM
Designer King
Paulporsche's Avatar
Jdub,
It has always been said that the cooling effect of the trombone system came from the length of the oil line itself that goes to it, not from the cooler per se, which is not much more than just a turnaround to get the oil flowing back.
I applaud your efforts (see motto below). I am just concerned that you might do something to your car, be unhappy w/ the cooling achieved, and then, when you get a better cooler, have mods to the car that don't work w/ the new system.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-07-2004, 02:24 PM
Me like track days
There is quite a bit of turbulent air around a trombone - cooling it pretty much to the max capability of this limited capability setup -
Old 09-07-2004, 02:33 PM
How's your oil pressure? If it is low, you may not be getting enough movement of the oil thru the system. If this is a track only car, some racers remove the right headlight and cut a hole into the back of the light bucket. But, you already know the number one fix.
Old 09-07-2004, 05:03 PM
OZCarrera3's Avatar
Jdub,
If budget is a consideration, think about a second hand 28-bar brass oil cooler. I recently fitted one to my car and now temps don't get over 185 around town (used to be 210-220) and 210 when giving it some stick in the mountains (used to be up around 240-250)!
It only coast $AUD400 versus about $AUD1,250 for the Carrera cooler. It also very simple to fit.
Sheldon
'92 964 Carrera 2 (Manual)
'07 BMW 335i
'76 911 Carrera 3.0 (Gone, but not forgotten)
"Give me ambiguity or give me something else!"
Old 09-07-2004, 05:12 PM
Randy Webb's Avatar
YOu are getting a lot of conjecture about the air flow regime that exists there w/o a vent. I rather doubt that anyone has done an eddy correlation, or even measured air speeds. I _doubt_ you are gonig to get any effective increase in cooling -- but maybe so. Take careful measurements and post your results. At worst, you will probably have a better flow regime into which you can insert a better oil "cooler" (exchanger), so I don't think you are wasting your time. Good luck.
Old 09-07-2004, 06:31 PM
I will tell you based on my experience how much "air flow" is going to help you cool your car down. As a trial, before I put on my Carrera type cooler, I simply bolted my high speed fan to my trombone cooler. This is a fan that maybe some others have bought that are 6" x 6" and were used an helicopters. Extremely high speed. I noted ZERO difference between with, and with out the fan. ZERO. I also noted the difference, with, and without the fan on my Carrera cooler, 15-20 degrees. You have an elephant coming at you, and you are doing nothing but swatting the flys before they land on his ass.
Old 09-07-2004, 06:51 PM
Me like track days
Good, some actual results - the same results as I had.
Ditch the trombone, it is cr*p for your use. The 28 row is a great system while the Carrera really needs air forced - and I mean FORCED - through it to be effective.
That said, I have *2* fans on a Carrera cooler - the standard 6" size (made by SPAL in my case), and a rare 4" SPAL that actually goes behind the headlight bucket! (They are impossible to find.....)
So, yes get the air in there with the future in mind -
Old 09-07-2004, 07:24 PM
I have heard it said that the engineers at Porsche had a plan when they put the cooler in the fender. The plan was that while the tire rotates in the fender it creats a vortex of air in a clockwise direction behind the cooler {thrombone or otherwise} causing a low pressure area behind the cooler being sure to cause air to flow from the front to thr back. I have no idea if this was the engineers intention or just the result of trying to find a spot big enough for the cooler although i suspect the former.
Jerry
Old 09-07-2004, 07:50 PM
Me like track days
Having worked in the aerospace world for 14 yrs - I suspect both end up being true. IMHO the trombone gets all the air it could possibly ever need - then, the design limits are reached rather quickly (where more air equals no more benefits)
Old 09-07-2004, 08:19 PM
"The plan was that while the tire rotates in the fender it creats a vortex of air in a clockwise direction."...
Yeah Jerry, but the Porsche engineers were planning on air temperature that was 80ºF, not 100+.
Has anyone said this yet? Drop the trombone and install an oil cooler in its place.
Sherwood
Old 09-07-2004, 08:24 PM
Me like track days
Yup, said it 3 posts ago, tough love style:
"Ditch the trombone, it is cr*p for your use."
Old 09-07-2004, 08:26 PM
Randy Webb's Avatar
OK, we now have two anecdotes -- that's actually progress...
Again, if you want to experiment, you go ahead. Post again if you want to know how to measure air flow in this area, and I will try to let you know what to do. I plan to do it sometime when I have spare time for playing around.
The conjecture about the wheel well tire induced wind vortex reminds me of a famous paper by Steven Jay Gould on the Spandrels of San Marcos. The bottom line: the spandrels were already there to support the building -- not for art work. The art work was just done later for "fun". The wheel well was likely an easy space to fit a cooler into - I will admit it is possible that PAG engineers measured or hypothesized on air speeds, but I've never seen this written anywhere. Post the cite if you have. It will be interesting reading.
Old 09-07-2004, 09:34 PM
[QUOTE]Originally posted by 911pcars
[B]"The plan was that while the tire rotates in the fender it creats a vortex of air in a clockwise direction."...
I read it somewhere, but cannot remember where.
Jerry
Old 09-08-2004, 07:51 AM
