ecm911's Avatar
Help - ident CIS tubes on 3.0
Can anyone identify any of the below:
1.Larger vacumn hose
2. Rubber hose attcahe to CIS box
3. Smaller vacumn hose attached to air box.
Also, the smog pump was removed from this engine, prior to my involvment.
I believe # 2and 3 should be attched to the smog pump, but not sure.
# 1 ???
I assume if I am correct and they related to the smog pump that they should simply be plug up. If not please let me know what to with them.
TIA
Earl
Old 09-08-2004, 12:40 PM
ecm911's Avatar
try this picture
sorry, new at this digital picture stuff. Hopefully this has my annotations. Earl
Old 09-08-2004, 12:43 PM
ecm911's Avatar
sorry, you can't read the numbers,
# 1- left hand circle
# 2 - center
# 3 - right hand circle
thanks
Earl
Old 09-08-2004, 12:48 PM
Designer King
Paulporsche's Avatar
Earl,
If you search the exploded views in the tech section, you will find a routing diagram for everything. There are two, so look for the one w/ the same decelvalve as yours.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 09-08-2004, 01:17 PM
