Help - ident CIS tubes on 3.0
Can anyone identify any of the below:
1.Larger vacumn hose 2. Rubber hose attcahe to CIS box 3. Smaller vacumn hose attached to air box. Also, the smog pump was removed from this engine, prior to my involvment. I believe # 2and 3 should be attched to the smog pump, but not sure. # 1 ??? I assume if I am correct and they related to the smog pump that they should simply be plug up. If not please let me know what to with them. TIA Earl
try this picture
sorry, new at this digital picture stuff. Hopefully this has my annotations. Earl
sorry, you can't read the numbers,
# 1- left hand circle # 2 - center # 3 - right hand circle thanks Earl |
Designer King
Earl,
If you search the exploded views in the tech section, you will find a routing diagram for everything. There are two, so look for the one w/ the same decelvalve as yours.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
