I would rather be driving
headlight connectors, I need a source
I am down to the last connections for wiring up the lights for the ST project. Lets just say that every wiring harness was cut instead of nicely pulling the plugs and fishing wires. So, the headlight connectors were cut before I got the car. I need a source for the oversized crimp connectors for H4s. They are not 1/4" faston type. They are indeed wider.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Jamie, I was able to purchase the whole connector with flying leads at my local auto parts store. I used to live in Austin, try the Auto Zone on South Lamar South of Barton Springs.
Cheers, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Thanks for the sources. Those are exactly the parts I need.
James, I will check AZ tomorrow, Its close to the house and a block from the 7-11. Slurpees keep me going through the hot days around here!
I use Bosch high watt bulb connectors that has screws to attach the wires.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
