Spacers
Hi guys,
I'm looking into getting some spacers for my wheels as the car has an after market widebody that is actually slightly wider than the factory's, (or so I'm told). What is the optimal fit for wheel/tire to the body? Should the outer-most edge of the tire be flush with the edge of the wheel well? Or is the rim that should be flush? (meaning the wheel would be a bit further out) So far I'm thinking 1.5 inches would move the fuchs' out nicely from their factory positions. Also, is ebay generally the best price for these things? They seem to be around $230 canadian or $180 US a pair for 1.5 inchers. Kinda steep! Can they be found for less? Thanks guys, Nix
1980 911 SC widebody, Black/Black. 1993 BMW M5. Silver/Black. |
I think you need 1 1/4" front and 2" or 2 1/4" rear.
about e-bay you can find good deals there but first check the Used Parts Classifieds on this BBS and rennlist
X/A |
RETIRED
Use the slip on type spacers and replace your studs with longer ones....don't be tempted to use the spacer/adapters that have pressed in studs....a little more expensive and time consuming but safer.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Hmm, I thought all spacers that were past a certain size all had the pressed in studs? So I should get longer studs and plain, no stud spacers? I suppose this sounds safer than having 2 sets of studs bearing the weight.
Anybody have any close up pics of a nice looking offset to wheel well position? Thanks, Nix
Crotchety Old Bastard
You don't say what wheels you have. Skinny wheels just don't look right on a widebody, even if spaced properly. It's a shame not to put all that space to good use. But nomatter what wheel size you have the long stud and spacer setup allows you to put the wheel exactly where you want it because you can use whatever size spacer you wish.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
I have 11" x 18" rears on my factory turbo-look Cab and I reckon I could have gone 12" wide rims to fill out the wells nicely.
I'm going to fit a pair of 1" rear spacers on mine to achieve just that.
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
