George,
Thanks to the link to the TUV site, I had a quick browse and clearly it will take some time to locate and digest the process required. I agree with your logic on the 930 brake system and if our intent was for our new system to be used primarily on 930's we might have an issue to correct. For a normally aspirated 911, the weight distribution and relative front / rear tire sizes are different to the 930, with rear tire load and grip affected (reduced) accordingly. If we had moved the static bias rearward, the chance of high speed rear lock-up would have increased significantly - being a far more dangerous condition than the risk of low speed front lock-up. We have the freedom to adjust the piston sizes in both front and rear caliper piston blocks, a relatively simple proposition in our modular design. If we detect an issue we are open minded about making the adjustment. Regards Hayden |
Hayden did you mention how much it improved Tracy's lap times using the new spring plates and bearing set up ?
2006 Cayman S 93 RS America white(now living in Arizona) 1974 911S/CARRERA (now living in Australia) Livermore Ca. |
I kind of discretely covered that above, I was keen to avoid any false advertising.... Although I thought Rich W hussling the car around at 1:48 with a passenger was significant Regards Hayden |
I was thinking both of the times were a strong selling points ..You make great products. I jus tput in a wevo shifter in my car .. works great and was easy to install. Will I see you at the open house on sunday?
What's funny is, while I was installing my new PolyBronze bushings a couple weeks ago, I was thinking "gee, Chuck should make motor mounts out of this stuff..."
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Larry,
Yes, we will be there on Sunday, I just heard that Bruce Anderson is going to give his "History of the 911" lecture a couple of times, which I am looking forwards to, plus they have a 3.8 liter, Motec engine they are going to run on the dyno every hour, 75+ degree sunny day, friends, dogs, hot dogs.... California life is good. Regards Hayden |
Me like track days
FWIW, I am looking forward to the WEVO suspension products ---
My 3.6 Varioram 911 suspension: JRZ adjustable shocks - fronts have the raised spindle type setup 2.5 front and 2.8 rear neg camber 225/245 A032R tires Sanders 22/29 hollow torsion bars Front monoballs BUT.....the problem area are the bushings - 5 years ago we installed the urethane jobbers - there is a lot of binding and endless squeaking. One cannot adjust these JRZ $hock$ properly with this much stiction. With the amont of time/effort and $$$$ I've put into this beast --the WEVo & Elephant setup is a MUST --
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Hope the WEVO brakes come to market; one can only hope!
J.P. |
Hayden:
'Have anymore pics of the front brake mount area? Pad box? Thanks, J.P. |
J.P.
Here are a couple of pics of the front caliper. You can see this is attached with the O.E. SC mounting bolts, no adapters etc. Regards Hayden
Me like track days
The setup you have pictured - is it fully functional as shown; ie
bolt it on my 911 and drive?
Craig,
Yes these parts shown are full functional protoypes. The only other things required to drive away a car like yours, would be a 23mm master cylinder and brake pads to suit your application. Regards Hayden |
For those like me who are "homologation challenged"; assuming you don't pursue any homologation, will the calipers be available without markings, and anodised black?
I know I am picky... Oh yes, and home delivered by a stripper?
George,
The silver color on these parts is nickel plating on the aluminum piston bodies, electropolished stainless on the fists and clear zinc on the fasteners (still certified 12.9 grade for those who know about this issue) In each case the finish could be made black without resorting to paint. Of course the WEVO text can be deleted in manufacture. Was that a male or female stripper for the delivery? In that I have limited choices.. Regards Hayden |
Hi Hayden,
Sounds better every time you chime in. We'll see what decisions you make on these. For the stripper, I had in mind that UPS girl that was on the web for a while.. Another domain you could research for non available products would be an oil recirculation system that is on the end cover of the 915 gearboxes wit the outer loop to a left front fender mounted cooler, like there was on the 3.0 RSR |
George,
Ironic that you raise the 915 oil re-circ system. We have a system in planning / design, it will be an exchange program, the front cover is machined / modified to accept parts - including a spray bar and return / relief valve. The oil out is effected through the bottom cover plate - a more sofisticated version of our GateShift bottom cover, including a small sump and debris screen. We had planned on using the LR fender for a cooler. Major limiting factor at present is sourcing an electric pump that meets my satisfaction. We went as far as scheming a dedicated (simple) peristaltic pump. The project is on hold at the moment, the only part we have tested is the oil-out sump plate - successfully completed a 25 hr test last year. Like any of the products we work on, the install is intended to have very limited irreversible impact on the car. Keep a lookout on Pelican, or on our site. Regards Hayden |
Hayden,
This is what I had in mind:
George,
A quasi-repro of the mechanical system is not out of the question, but I have never been comfortbale with the longevity of the drive mechanism for the pump. Perhaps not an issue on a race car lavished with factory care, but a street / track car where long service intervals are expected and simple remedial care is considered normal, I was heading towards an external pump. Regards, Hayden |
Maybe you can consider selling the cover seporately?
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
Hayden,
Funny, my RS (and every one that has more than 50K miles on its gearbox) has a broken drive for the inner pump. Does the RSR outer pump use the same drive setup? if yes, then at the very least a beefup of the design (which is IMO more elegant), or indeed another drive seems indicated |
