Registered Cruiser
jorian's Avatar
Question Idle Problems
My 3.2 is surging at idle. Goes from 900 - 1100RPM every second. Very annoying. Bentley says a high idle (1200) is a defective switch but doesn't mention the surge issue.
Any suggestions? (Be nice...)
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 09-17-2004, 05:00 PM
ausgezeichnet's Avatar
I had the same exact problem on my 84 3.2L. I had to upgrade the cylinder head tempature sensor from the old single wire to the newer 2 wire sensor. It took care of the surging.
Mike
'84 911 Carrera Coupe (totaled)
'83 911 SC Coupe
‘06 Aston Martin Vantage V8
Old 09-17-2004, 06:40 PM
vash's Avatar
buddy of mine did all sorts of stuff. ZOANAS. maybe do a search under his name. i seem to remember his issue was fixed with a mixture adjustment.
poof! gone
Old 09-17-2004, 06:57 PM
Registered Cruiser
jorian's Avatar
Mike,
Where did you get the Sensor? How much?
Thanks.
Vash,
Thanks for the input. Will search out ZOANAS.
Jorian.
Old 09-17-2004, 07:01 PM
Make Bruins Great Again
Por_sha911's Avatar
Also, check your ICV (do a search). It can be cleaned (Cost is a little carb cleaner and some time).
Joe
Old 09-17-2004, 07:25 PM
kqw kqw is offline
When was the last time the O2 sensor was replaced? Also good advice from Joe on cleaning the ICV.
The Fox
Carrera
Old 09-17-2004, 08:50 PM
Before adjusting the mixture, you might want to set the idle adjustment screw. Steve Wong provides a pretty good explaination here (about halfway down):
http://www.911chips.com/dmeconvr.htm
Tim
1986 911 Cab
2008 Audi A6
Old 09-18-2004, 08:13 AM
Jorian,
Here is a link to a post I made yesterday that has the part number for the sensor.
Cylinder Head Temp Sensor Replacement Lessons Learned
Mike
'83 911 SC Coupe
Old 09-18-2004, 08:51 AM
