Sports Purpose 911 Driver
mjshira's Avatar
964 decklidinstall question
I recently purchased a 964 decklid (thanks Jack) and have set up the wiring. The only thing is that it doesnt work. I have power to the switch and through it. The ground is good. The line to the tail is plugged in correctly.
Anyone have any ideas?
Thanks!
James
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 09-18-2004, 08:41 PM
unimog's Avatar
If the decklid is on your '72, then you might want to check out
http://66.34.72.138/howto/c2-lid/index.html
There are great wiring diagrams there for the lid conversion.
If it is a 964 lid, on a 964, then ???
'04 BMW R1100S BCR
'01 Audi TT RS
gone but not forgotten:
'87 911 Carrera '59 356 Coupe
'66 912 Speedster '99 996 Ducati
Old 09-19-2004, 04:01 PM
mjshira's Avatar
thanks. its on my 72. I think that link is for tyson's diagram? I have the wiring correct, but she dont work!
Old 09-19-2004, 04:03 PM
unimog's Avatar
Well according to the diagram (I have a 964 lid, but it is not electrical connected yet), you should be able to put 12vdc power to the green and blue wires from the lid motor, and depending on the way you hook'em up, it should drive it open or close. If that works, I would ring-out the two micro-switches on your lid, to makes sure they are working correctly. And of course the door (well now a lid spoiler) switch. You could also leave the micro-switches out of the circuit for troubleshooting, but be sure to be able to cut power to stop the motor travel. Maybe a simple SPST switch in the incoming power. Also you can disconnect the cable from the motor to the spoiler/wing, to safe guard against over-travel, and reduce the variables, by one.
Good luck. Holler if you have success, or more questions. YMMV
'04 BMW R1100S BCR
'01 Audi TT RS
Old 09-19-2004, 05:50 PM
mjshira's Avatar
thanks Mark! I am on a business trip, once I get back to Scruffy I will test that and let you know, much appreciated.
--James
Old 09-20-2004, 05:18 PM
