84toy's Avatar
Front cooler install
I am in the process of installing a front cooler and I am nearly done. My only disappointment is the cooler is in front of the air inlet for the A/C condenser fan inlet which I know won't help the A/C.
While apart, I tossed the old horns since one of my horns was bad anyway and replaced them with a set of Cadillac horns. ($5.00 at Pick and Pull) Turned out to be a nice improvement in the "noise" category.
Bottom Brace (rubber lined)
Top Bracket (rubber mounted)
Cadillac Horns
Paul S
"Those who say it cannot be done should not interrupt the people doing it"
Old 09-19-2004, 04:16 PM
Moses's Avatar
Very nice! How much room do you have behind the cooler for air flow?
Old 09-19-2004, 04:28 PM
84toy's Avatar
Not a whole bunch. About 1" average. I was quite worried about that part but it seems that these big coolers have enough cooling capacity that it is not a big issue. I bought a BW valance and removed about 1/2 the rolled lip of the opening for the cooler. This allowed me to move the cooler forward a little more.
Paul S
Old 09-19-2004, 04:32 PM
Moses's Avatar
Mine only has about an inch but seems to work well.
Old 09-19-2004, 04:37 PM
Nice job on mounting the cooler. It even looks like you could add a "crash" bar that spans between the two support brackets in case someone decides to intrude in this space. Are they aluminum like the upper mounts? Might even be good mounting points for an add-on splitter under the bumper.
Sherwood
Old 09-19-2004, 04:38 PM
Yellowbird RS's Avatar
Nice setup!
good job
X/A
Old 09-19-2004, 06:25 PM
Bill Verburg's Avatar
More cooling than you'll ever need
Bill Verburg
Old 09-19-2004, 06:58 PM
warpspd's Avatar
Send a message via ICQ to warpspd
Where did you get the cooler at?
Ryan
Cimarron region PCA member
98 Boxster
Old 09-19-2004, 07:57 PM
84toy's Avatar
I got the Setrab cooler from Chuck Moreland at Elephant Racing
Paul S
Old 09-19-2004, 08:29 PM
Chuck Moreland's Avatar
Paul, very clean install. I like the bottom bracket you fabbed. The rubber is a nice touch.
Chuck Moreland - elephantracing.com - vonnen.com
Old 09-19-2004, 08:52 PM
