WydRyd's Avatar
Testing Injectors?
Hi,
What's the best way to check/test if an injector (or injectors) are clamping down under heavy load?
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 09-19-2004, 08:41 PM
Merv,
You can use a NOID light whi you can get at many auto parts places. It gives you a light and confirms the electrical circuit. Flashing is good solid or out is bad. However this does not test under load............unless you can get a friend to hang on to the back of the car while you drive. Or use a dyno!
Cheers
Mark.
Old 09-19-2004, 09:10 PM
