				Replacing fuel lines in tunnel
			On my 82 SC Coupe (low milage about 94K miles)I continue to have a slight smell of fuel coming from the tunnel.  I especially smell the fuel when I have the sun roof open.
				It is my understanding that the fuel lines are steel. Anyone have an idea why they would have a leak? Guy Chiattello  |
			 19 years and 17k posts...
			Could the fuel leak be above that area and dripping down? My fuel leaks were behind the CIS stuff at the top of the engine, but the gas dripped down along the lines to the fuel pump (my fuel pump is in the rear, behind the tunnel).
	Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com  |
			I just had to replace my pressure line. Not sure what happened to it. Three is a section of it that is rubber. Could that be where your leak is?
	'86 911 targa '04 MB 230K Sport (daily)  |
			So did you already replace the line or do you think you need to do so?  First, pull the belly pan off and have a look at the fuel pump and see if there's any wetness.  Any drips under the car?  When this happened to my Carrera, it was the banjo fitting that goes onto the fuel pump.  Probably could have jury rigged it, but I did it right and had the entire line replaced in the tunnel.  Major job.  Track it down before you go through what I did.
	2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS  |
			Thanks for the input.  I did check the banjo fitting and other areas and find no fuel leaks.  It may be the rubber portion of the pressure line.
	I did look at the threads on replacing the lines. Looks like quite a job. Guy Chiattello  |
			You are probably leaking at the swedged sitting where the rubber meets steel.  It is usually the pressure line rather than the return line.
			The job isn't that bad if you plan ahead for it - it sounds a lot worse than it actually is. It will occupy at least a Saturday, maybe some of Sunday. The easiest way that I have found to do it is as follows: Run the car until you are really low on gas - 5 gallons or less Drain the fuel tank, disconnect the fuel lines from the tank. Remove the battery and fuel tank. You can skip the fuel tank - but it is a lot easier to pull the hose and install the new one with the tank out. It only takes about 15 minutes to remove a tank Disconnect the fuel line from the engine and the fuel pump. Remove the Center tunnel access plate Pop out the grommet that the fuel line rides in. Remove shifter (for installing the new line) Pull the line out. Installation is the reverse of removal. It may slide easier if you coat the line with silicone spray lube. Tape up the ends of the fuel line so to do not get foreign material in it. When feeding the line back in, on the drivers side of the center tunnel, you will feel a guide that the fuel line has to fit in (keeps it away from the shifter linkage) - you pull the fuel line through and guide it into that guide - repeat at the rear of the center tunnel. AFJuvat
	Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information  |
			AFJuvat,
	Thanks so much for the step by step directions. I will order the lines and go at it. Guy  |
			Guy,
			FWIW, I just replaced both lines in my 77. I used a vice grip with tape on the jaws to clamp the fuel line at the tank - didn't have to remove the tank or drain it. Also, I taped a 3/8 plastic hose to the end of the fuel line, then pulled the fuel line out the front, and then used the 3/8 plastic hose to pull back the new fuel line. I didn't have to remove the shifter. Good luck. It's pretty easy to do, just takes some time. John H.
	'77 911S with a 3.2 for me '98 Toyota 4Runner for the snow '00 Ford Ranger 4x4 for the wife '92 Volvo 960 for the kid(s)  |
			John,
	That sounds like a great idea! If I don't have to remove seats and shifter and all that, sure would make it easier. guy  |
				Help on Fuel pressure lines
			I just recieved fuel pressure lines from our host and I am confused.  These are to replace the lines in the tunnel and the one shown in the Pelican catalog is straight.  The one I received has a number of bends.  Frankly, I don't see how it would fit in the tunnel.  The part # is the one listed in the catalog and I spoke with someone at PP and they assured me that this is the right part.
	Just got a digital camera and will attempt to post a picture. john hejmanowsk or AFJuvat Guy Chiatello 82SC Black Coupe
			 Insert Tag Line HERE.....
			Uh, nope, that aint right..
	Marc  |
			No, that does not look like the correct fuel line.
			AFJuvat
			Here is a pictuer of the fuel system\lines.
			The pressure line is part number 33 - 911.356.066.08 the return line is part 38 - 911.356.062.08 AFJuvat EDIT: Guy, your PM Mailbox is full.
			Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information Last edited by AFJuvat; 11-03-2004 at 08:36 PM..  |
			Here's my take on it: Replacing pressurized fuel line from pump on 78 SC?
	2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar)  |
			Guy, you have the wrong part. The steel line you show goes in the engine compartment (there are actually two, one the pressure line, one the return line). The tunnel has two lines. Each one is a hard plastic connecting to the steel line(s) with a flexible hose end at the fuel tank / fuel pump.
			You need part 33 and 38 in AFJuvat's diagram. John H
			Thanks everyone.  This has been extremely helpful.  I will send what I have back and get the right lines.
					I also learned how to empty my mail box. Thanks AFJuvat!  |
