Alright....
Exhaust design
The wonderful topic of exhaust! I need some opinions... I have read some of the longer treads on mufflers and have decided to go with a Dynomax Ultra Flo muffler. For cost (mainly) and sound.
'74 2.7 w/headers My question is this, is it better to go with a system that collects the exhaust before the muffler, IE a single inlet muffler with a collector before the muffler, or a dual inlet muffler that would bring the exhaust down to a single outlet. The car is setup for a single exhaust pipe and I don't plan on going dual unless there are some reasonable options for a new rear valance. Here are the two mufflers I am considering: 17283 17519 What do you think? |
Alright....
Alright....
No opinions? Someone at least rag on me for using non-German parts!
Stephen Friendswood, Texas '78 Targa w/ '86 930/20 w/ '74 915/06 |
RETIRED
Buy a dual outlet/inlet Bursch.....remove the valance, polish the Bursch...be happy.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Supertrapps! Like these sticking out the back of my car (the orange one) in this admittedly bad pic:
Mike
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
I am using a Dynomax on my 3.6. I love it! The sound is beautiful, not obnoxious like so many aftermarket mufflers.
I have a Bursh system off of my 3.0 with back dated heat exchangers from an erly 70's 911. It's a dual inlet, single outlet muffler in very good condition, could even polish it for you like Mikez said. Could measure up and compare with yours to see if it would fit. Let me know if you're interested.
-Jayson 1976 911S Signature Edition - 3.2SSt (JE 98mm 9.5:1 pistons, 964 Cams, Carrillo Rods, ARP Head Studs, AASCO Valvetrain, 3.2 Carrera Manifold, ID725's, B&B Headers, TS HyperGate45 Gen V, TS RacePort, BW S360, AEM Infinity 506, E85) IG: Signature_911 |
RETIRED
How much are you asking for JUST the muffler?
Looking to get around $150 for it. I only had it on the car for a few months and then forked over for a B&B system with a catalyst.
Administrator
Porsche_911s, refresh my memory: doesn't the 2.7 exhaust have a crossover pipe leading to a single outlet to the muffler? If that's the case, it seems like it would mean a lot of aggravation to run a second pipe from the leading edge of the motor all the way back to the muffler.
I'd stick with a single-inlet. I have a Flowmaster, which I like a lot.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Alright....
The '74 2.7 does not have a crossover pipe. I currently have an OEM style on there right now. The headers connect directly to the muffler.
Of course this is not my actual muffler, just a pic. |
Alright....
The exhaust measure 25" from center pipe to center pipe. It's a two bolt flange and measures 3" inches from center bolt to center bolt.
'74 used the old style copied and improved by SSI.
Just get a Dansk or Monty oem twin in style. Personally I like the 2 out but it will likely be louder.
If your original ? was about this type of exhaust
![]() You would have a very dificult job to repipe
Alright....
DAMN!!!! I take it that's not street legal?
Here's another version that is street legal
![]() Talk to Steve Weiner at RennSport Sytems about this one. I don't know how effective these are on a flat 6. On a V8 they are very effective because of the uneven firing pulses that always exist on one bank of cyliders(on street V8s).
I'm currently making a custom exhaust for my Porsche powered VW Crewcab. I was using Supertrapps w/9 disks and internal mods. I switched over to a pair of Jones Exhaust mufflers. They are 12" long (available in 12"-24" length) 2" in/out, 4" diameter, and weigh 8lbs. ea. I used the "turbo" model. It's as loud as the Supertrapp I removed. I'm fabing up some Ansa tips to bring the noise down a little more. I have a pair of 18" mufflers I'm going to try on our 2.8 twin plug race motor.
The best part is the mufflers are $18 ea. I would try the "super tubes" for the race car. Worth a look. http://www.jonesexhaust.com
Harold '79 930/DP935 (sold) '68 VW 3.3 Turbo Crewcab |
RETIRED
The blue header and exhaust setup on the Yellow car is just not right. 'Cause it should be on my car! Woodie, woodie, woodie.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
Administrator
If you've got the old-style headers/exchangers, then I think the low-cost answer is to get a dual in, single out muffler (like a Flowmaster), but with an inlet on each side (like a Camaro muffler from the late 80's?).
