window problem? When it is wet here...
my power driver's side window is slow coming down. Is it just sticking because of the added friction from the water in the window guides or is it trying to tell me something?
thanks! |
Montana 911
mine has done the same thing for years, and is now to the point where I have to assist it on the way down. I was told it could be a worn regulator or just needs adjusting.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
Channel felt.
Don 24 Cayman GTS - GT Silver 23 Cayman GTS - Arctic Grey - Sold 97 993 Coupe - Arctic/Black - Sold 13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue |
Designer King
Those channel rubber/felts can be changed. Until then try some WD40 to dry them up, then some spray lube. Wax may also work.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
Re: window problem? When it is wet here...
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Smart quod bastardus
My hand powered windows do the same thing.....very hard to turn them down, up is easy.
I usually spray WD-40 as a lube in the felt guides to assist in making them really easy but that lasts about 4-5 weeks and then they are sticky again. The felt are in great condition......so I dont see how they could be the problem....can someone give more detailed explanation or a fix?
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max ---"When you're racing it's life! Anything else either before or after, is just waiting" |
fwiw, sometimes the glass and frame alignment in/out is causing some binding. After removing the panel and loosening the frame alignment multiple bolts I work the alignment to give the easiest glass load. It's sort of a comprise as your watching the frame move in & out.
Somatic Negative Optimist
Check the "squeegy" rubber seal. It gets hard over the years and is very easy to replace.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
the two outside rubber seals on each window is an easy fix with the frame out.. otherwise it's a pia and a near scratched paint.
The ouside "squeegy" is easy: Lower the window all the way, working from the INSIDE with a flat screwdriver, carefully lift the steel trim moulding which holds the rubber squeegy. The moulding is held to the door with clips fitting into small holes, it comes out fairly easy. Now you can slide the old rubber out, clean the trim moulding and slide the new rubber in with the help of some WD40. Put a little Vaseline onto the clips and pop them back into the door. It took about 30 minutes for both sides. The trick is to lower the window and work from the inside; no scratched paint. Cheers.
Silicone lube in the felt channels will speed things up. I found it lasted over a year before they started to slow again. WD40 lasted about a month.
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
My gues is a binding regulator - my left side broke altogether a few years back and needed to be replaced. The right side is hanging in there but needs help going down and goes up easy.
Porsche changed the design of the window regulators back in the mid 80's. The new design is the only one available now. It's not TOO difficult to replace, but you have to drill a new hole in the door braces and replace the runner on the bottom of the glass. A PIA actually. The Haynes manual has a detailed procedure with a picture. As I said - I had to replace mine because it broke. ...now that I think about it, I saw an ad once for a doomahicky which fit on the old regulator to brace the stressed joint. It wasn't cheap, but a lot cheaper than a whole new regulator and guide rail. I *think* PP had the part, but maybe Wayne does too.
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
