Now when you guys say messy, do you mean it splatters metal drops? If so, can't they just be ground off and most of the area covered for protection. Maybe I read something wrong but it sounds like flux will work, it is just messier, and more clean up afterwards. If that is the case, heck I'll use one of those because 1) they are cheap, 2) I am cheap, 3) I have a grinder to clean up with already and 4) anything I do is going to need to be thin bondo anyways. Oh, did I mention that I am cheap.
Thanks, David |
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
the smoke aslo makes it alot harder to see what you are doing,
Jim
Jim Hamilton If everything seems under control, your not going fast enough. |
Metal Guru
The molten flux floats to the top of the molten metal because of it's low density and forms a "glass" slag on the surface of the weld bead, not in the weld. Flux Core wire was intended for structural welding and production welding of components with thick cross sections. You weld sheet metal with it at your own risk.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
It's been several years since I've used flux-core, so my memory is hazy. I do remember grinding welds and finding 'pinholes' which I assumed was from flux contamination. I was too cheap to install a flux capacitor, instead opting to go the full-MIG route.
