Formerly bb80sc
Vipergrün's Avatar
Which adjustable front swaybar upgrade for an SC?
I currently have a Carrera 22mm non-adjustable front swaybar on my SC. I am looking into installing an adjustable 22mm bar. From reading 101 Projects, it looks like a pretty easy project. I am considering the Weltmeister 22mm kit. Anyone have this bar, or any comments on it? Does this one come with adjustable drop links? Are those necessary? What other 'affordable' options are there out there?
TIA!
-B
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 10-02-2004, 02:34 PM
Bill Verburg's Avatar
Don't know about affordable but Smart Racing has some very nice ones, As does Elephant Racing
Bill Verburg
Old 10-02-2004, 02:46 PM
Jeff Alton's Avatar
Brad, I took off the late carrera bars (22/21) and put on the Elephant Bars. Nice and light and hi quality. I also do service work on a car with "charlie Bars" and IMHO the elephant bars are a better product. A little pricey, but you get what you pay for.
Jeff
www.turn3autosport.com
Old 10-02-2004, 03:02 PM
DByers's Avatar
Brad, I have the Welt on Stay Puff. Good bar for the price. If you can swing it I would look into the Smart Racing Product. Thats what Todd is running in the front of his SC per Tyson suggestion. I think the SRP will also allow you to jump up to 30mm bars.
Man you are one mean track ho!
Missed you at breakfast this am. Harold showed up. We need to set a beer night, soon.
Dan Byers
Old 10-02-2004, 03:09 PM
Smart quod bastardus
fredmeister's Avatar
Weltmeister work fine for the money, however the design they use of a 4 sided hole in the adjuster bar ends is a weak point. The hole egged out and wound up with alot of slop between it and the sway bar where they connected to each other. No matter how much I tightened the clamp bolt, it still rocked against the sway bar. Adjustable drop links are a must if you wish to properly dial out any preload.
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 10-02-2004, 03:13 PM
