I have a 1974 911S, which was rebuilt w/ weber carb conversion about 8 years ago - not much paper work existing.
The car is in great shape and runs very fast. BUT about every few hundred miles the plugs get clogged. Sometimes I will drive it until it cleans itself out, which is not much fun on a few cylinders short. Some other times, I have taken out the plugs and cleaned them. This always fixes the problem, but it's a pain to do so frequently. Any advice/ideas out there? Thank you. Bill
74911S |
RETIRED
A fouled plug can be from rich conditions or oil.....a compression check or a leak down will tell you if that cylinder has a problem.
Is it always the same one(s)? Runnin g a can of Techron thru the fuel system wouldn't hurt....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Re: Clogged Spark Plugs
plugs carb jetting carb size ignition timing curve camshaft compression test type of driving
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Bill,
Sounds like your carbs need to be removed, disassembled, and soaked overnight in Berryman's Chem-Dip. Outdoors, please, and wear a charcoal-filter respirator rated for chlorinated solvents when working around the open container you are soaking the carb parts in!!! A large metal trash can, inverted over the carb parts and tank while soaking might minimize the environmental effects to bystanders such as kids and pets while the soaking/cleaning operation is going on.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
What plugs? Some people run a colder plug when tracking the car or in the summer if it's hot. You could have these 'cold' plugs.
Going back to CIS will simplify everything and will deffinitely solve your problem.
