Somatic Negative Optimist
Using the 98mm Max Moritz, or JE P/C, on a 3.0 liter SC engine, are the wrist pins reusable? Or do I need different ones? Other than new rings for the 98mm P/C, what else do I need to make this work?
When ordering 964 cams, or Webcams 20/21, what cam timing is to be expected with CIS? Is the cam timing provided by the supplier?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Hilbilly Deluxe
I don't know about JE, but Mahle pistons come with wrist pins.
I timed my 964 cams per the factory 964 spec. I don't remember what it is off the top of my head, but it is probably in Wayne's book. On a 80-82 small port SC, get your ports done, and use the early SC airbox/CIS runners. Your engine will run out of breath up top. Tom |
There are 3 different versions of the Mahle 98mm p/c
the 3 liter CIS version has a 22x61mm wristpin which is compatible w/ the SC con rods. These are slip fits but do need a slight chanfe on the heads cr 9.8 the 3liter MFI version has 22x58mm pins which are also compatible w/ stock SC rods, installaaton as above cr 9.8 the 98mm Motronic have a 23x58.5mm pin. installation as above cr unknown wristpins are supplied w/ the kits usually, MAhle wil last longer than JEs, cam specs are supplied by the manufacturer.
on the cams, get them from camgrinder on this board and he will help you out with things.
Andy |
Somewhere in the Midwest
Andy have you bought from "camgrinder" I'm going to need some soon. E-mail me if you'd like. Thanks.
Hilbilly Deluxe
http://www.elgincams.com/ Tom |
Doesn't want/need a 3.6L
Ralph EDIT: I take that back, I know it was offered up until a year ago because my friend is using this set in his 3.4L twin-plug. Last edited by Carrera3.5L; 10-13-2004 at 08:43 PM.. |
Souk, i have bought from camgrinder and highly recommend him.
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thanks guys, I had no idea "camgrinder" was with Elgin...no need to say anymore
So, if I go with Mahle 98mm P/C, is there a seal ring between Cylinder and head just like I have now with 95mm? There is also a thin copper seal on the bottom of the 95mm Mahle Cylinders to the engine case. What seals, top and bottom of the cylinders, is used with the 98mm?
Hilbilly Deluxe
No sealing ring on top of 98mm cylinders. They use the same copper base gaskets as the 95mm jugs, as they are the same size externally,
Tom |
