Bill Verburg's Avatar
You can see where the nubs in the throat have been ground down, Other than that I have different versions of the above shot
Here is a 964 rear modified for 3" trailing arms, same sort of mod to the throat, but the ears remain and are redrilled
Bill Verburg
Old 10-06-2004, 07:46 PM
Yes, the Big Reds are aptly named
This is the 993tt rear, 965 rear and M rear
Bill Verburg
Old 10-06-2004, 07:56 PM
Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Bill, got any shots of the holes made in the caliper for the adaptor. Thats the part that makes me most nervous, milling into the caliper.
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 10-06-2004, 08:02 PM
Somewhere in the Midwest
MotoSook's Avatar
John,
I'm with you. Drilling into the caliper is the nervous part. The adapter will be easy. I suppost once I take the calipers apart ans cut the ears off, it'll become obvious, but any information before the operation is good to have....
Old 10-06-2004, 08:47 PM
MBruns for President
JeremyD's Avatar
Why go 944t? The 993's are so much easier to adapt - around the same price - nothing to drill
Old 10-06-2004, 08:58 PM
MotoSook's Avatar
Jeremy, If I could find someone to trade 993 calipers for my 951 calipers, I'd be right there!
Old 10-06-2004, 08:59 PM
Stahlwerks.com
jhelgesen's Avatar
Cause its what I've got on the shelf, no other reason.
John Helgesen
Old 10-07-2004, 05:07 AM
I highly recommend the 993 front and 965 rear caliper combo on 930 rotors. They are so much easier to deal w/ and give much better results than the 964s
The 993 calipers aren't that difficult to get a hold of or expensive
Bill Verburg
Old 10-07-2004, 02:29 PM
JeremyD's Avatar
I bought a set of 951 calipers off ebay fronts and rears - then started doing research on what it would take - I read just about everything that Bill had to say on the whole Brake subject. (kinda spooky, eh Bill?)
Anyway - I sold my 951 the next day.
Old 10-07-2004, 06:40 PM
which rotors are you using with the radial mounted 964/944T calipers?
WWW.9GEAR.NL
Old 10-07-2004, 07:14 PM
armandodiaz's Avatar
Here's a dump questions which I've always woundered about when talking about caliper prices.
Instead of buying used calipers or these expensive kits, why not just purchase the calipers from an autoparts store(eg. Advance Auto Parts) then purchase the rotors and adapters seporately?
From my research, you would end up spending approx. $2300 total, instead of the $3500 one could spend. And the calipers are lifetime guarantee.
front calipers: $160.00 ea
rear calipers: $175.00ea
Armando Diaz
85 911 Carrera - Track car
01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996
87 944na - Old Daily Driver, now 944 CUP
03 Chevy Avalanche- Support Vehicle
70 Olds 442 W30 Conv- Gone but not forgotten
http://www.diazracing.com
adiaz@diazracing.com
Old 10-08-2004, 06:26 AM
MotoSook's Avatar
Armando: that was discussed in my rant thread about the $59.99 caliper fron the FLAP I might just try that.
Old 10-08-2004, 07:40 AM
911-32's Avatar
One would usually expect to use the early 944T rotor (as per the VCI kit). Its 4mm thicker and a little larger diameter than the 3.2 rotor and the same size as a 964 rotor.
Richard
Old 10-08-2004, 08:48 AM
I'm glad I'm not the only one with this thought.
Armando Diaz
Old 10-08-2004, 10:00 AM
Richard
I remember reading about a narrow body 964 front rotor will work on a Carrera if the outer edge of the front hub is shaved. No other mods required. Is this true? Does anyone have any experience in this?
Armando Diaz
Old 10-08-2004, 10:06 AM
911-32's Avatar
I have seen pictures of it on this forum but have no experience. They were in one of the major multipage threads regarding brake upgrades and it was perhaps a 993TT disc, but the hub mods were the same. I chose to use the 944T disc with 5mm bearing spacer because it had been done before (see the VCI kit) and I knew it would work.
HTH
Richard
Old 10-11-2004, 07:14 AM
Originally posted by mr.bch
I can post the file tomorrow from work (I drew mine in UG). I didn't get all crazy with removing Aluminum like some do. I left them pretty basic. I didn't want to get skinny on something that might fail, brakes generate more power than the engine afterall. I have extras with grade8 zinc hardware for sale cheap, too. But I'd be more than happy to share my data with everyone. If you have a format that you prefer, let me know. .x_t, .igs, .dwg, .prt, .dxf, whatever, I do it all
Hi mr.bch
What calipers are your adapters for? Do you have the plans in PDF format?
Great forum btw. I've been a lurker for a while.
Old 10-16-2004, 02:12 PM
996 normally aspirated. I forgot I was going to post the print I made up at my work. Bill V always does such a good job of posting brake info. Problem is, there are so many different combinations....
Old 10-16-2004, 04:36 PM
996 calipers are the same as the red Boxster S ones aren't they? I have a set of these I would like to fit but the price of the adapters is prohibitive. If I had the specs I could probably make them myself.
ta
Mathew
Old 10-17-2004, 04:47 AM
yes, 'S' and non turbo 996s have the same part number, from my research.
I'll dig out my file when I get to work tomorrow.
Old 10-17-2004, 10:09 AM
