Removing Tinware
Hi
I've done a search but couldn't find a definitive answer on whether I can remove the engine tinware with the engine in situ.
I started doing a general cleanup of the engine by which has progressed to me wanting to powdercoat the tin.
I've removed the bolts at the rear and side but can't see how I can get the rear section past the engine support bits.
Ron
Old 10-03-2004, 04:57 AM
Zeke's Avatar
I think with patience you cna get most of it off. With the exhaust off, it should be able to be done completely, AFIK. You can always lower the engine 2-3 inches to get at another bolt. I find a 1/4 drive socket helps.
Old 10-03-2004, 08:58 AM
